Page 4 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 46 to 60 of 71
Thread: Reed Stoppers
  1. #46
    Sep 2006
    Key Largo, Fl
    Quote Originally Posted by DanUmbarger View Post
    I emailed Chris about what reeds to use and he recommended the 144R reeds. It appears they sell 3 different types...S, R and D...standard,race and drag. Now I'm curios how long these reeds will last and should I have gone with the "s" type. This is not going to be a race boat but I'm going to try to run this motor at the upper RPM limits...prolly 5800 - 6200 RPM.
    They will last a long time...they're are a little stiffer than the sport version,Chris
  2. #47
    The 265xr , is that a small five panel? Sport version?
  3. #48
    Sep 2006
    Key Largo, Fl
    Large 5 petal used in hipo 3.0 mercs,Chris
  4. #49
    Slightly disgruntled
  5. #50
    Sep 2016
    McHenry,Illinois
    Thanks for clearing that up for me Chris
    Quote Originally Posted by Chris Carson's Marine View Post
    Hustler 15' Wildcat / Merc 80
    Hustler 13' Wildcat / Merc 80
    Hustler 13' Picklefork (Experimental) / Merc 80
    Hustler 16' Victor / Evinrude 85
    Hustler 15' Tunnel / Evinrude X115
    Hustler 17' Lark / Suzuki 140
    Ranger 17' Aztec / Merc 115
    Hustler 16' Victor
    Hustler 16' Victor / JohnRude 135 (current and restored)
    Hustler 15' Family Tunnel / Johnson GT115 (current project)
    Hustler 16' Victor
  6. #51
    what do you call a long time ? a long time to some is a short while to others.
    a teenager thinks 2 weeks is an eternity
  7. #52
    Sep 2006
    My first set of CCM reeds are still going. s series to 6800 and I can't remember how long ago I bought them
  8. #53
    well atleast give us a rough idea, 1 year , 2 years, 3 etc.. no point saying a long time and then I cant remember.
    I have heard of reeds lasting less than 50 hours, some less than 20 hours, and some that broke straight away after a bad sneeze on start up.
  9. #54
    Sep 2002
    Solvang, Calif
    I would ask probable HOURS not years.
    Quote Originally Posted by phillnjack View Post
    Gary
  10. #55
    Phil ,
    In all sincerity , there are those who can make a toothpick last a year while there are those who can break an anvil with a rubber mallet within hours . There is no telling what type of skill set you possess have or have not .
    If your the type that needs to be protected from yourself , then as my homeboy the used car manager says , Sir I'm sorry , the new car lot is on the other side of the dealership ... >
  11. #56
    Phil ,
    Mr. Carson is without doubt on of the most fair and honest hard working people I can think of .
    I bought one of those sets of yellow reeds from him back when I had black hair ...
    They went maybe 100 hour's because the rubber on my blocks were bedded in and dry . I think that might be one of the ones with a brown spot on the upper left corner . Can't hardly fault the part , for piss poor installation ..
    Merc carb's have 3 little holes under the throttle blades . Back when I was filling them shut and hand drilling them to what I wanted .. so I could blast off idle clean , I managed to rip one yellow leaf off of a prepped block , but never once since he went to the white reeds .
    Or maybe he still sell's the yellow reeds , but to only those who are mature enough to have em ...
    Every used white reed in that box has aprox 250 hours on them . The ones on the blocks with the shorty stops came off of other peoples motors , I turned em over and ran them on my junk for another hundred hours . At the time , they were just starting to chip on the leading edge of the storm ..
    So , 250 to 350 hour's in the hands of your typical boat guy ... less if you a total ( how you say ) wanker .....
  12. Likes DanUmbarger liked this post
  13. #57
    8 Post(s)
    wankers is for aussies....
    brits use tosser
  14. #58
    Been dealing with Chris for years, have installed countless sets even in race applications and maybe 1 set had a tip crack.
    As for longevity.....proper installation is also a key factor.
    I can personally tell you from experience, he is very fair and honest.
    He has also improved them through the years.
    All brand break or fail like a motor does from time to time.
  15. #59
    Scribed
  16. #60
    brits use tosser
    See brother ... I was lookin out fer ya ..
  17. Likes phillnjack, powerabout liked this post
  1. Mercury 7 peddle reed plate, 1" spacer and reed blocks
    By tgreen in forum Misc. Parts and Accessories
    Last Post: 02-01-2016, 07:27 PM
  2. Mercury Tech: Clamshell Cowl from vertical reed , need to use on a horizontal reed engine. How?
    By Zoomba in forum Technical Discussion
    Last Post: 04-25-2015, 11:17 PM
  3. 5 pedal reed plate carb and EFI different size reed openings???
    By kyleweeky in forum Technical Discussion
    Last Post: 01-30-2015, 01:46 AM
  4. Yamaha Tech: TDR/reed stoppers
    By DoktorC in forum Technical Discussion
    Last Post: 08-18-2009, 05:40 AM
