Results 1 to 12 of 12
    Feb 2005
    245 Carb Merc Parts Swap
    I don't have a 2.5 EFI horn front end to check this with, so I thought I would just ask!
    -I have a 245 Carb and I have a EFI 2.4 Bridgeport(horn motor)
    - Can I take the front of the crank case to the horn off the 2.4 and put it on the 2.5 for an injected motor?
    - Will the electrics/ECM work on the 2.5, or do I need 260 Parts? Or did I just make a 260?
    If anyone has tried this please let me know if it is possible!
    Thanks
    ttopp
    TX......somewhere?
    Quote Originally Posted by ttopping View Post
    Thanks
    ttopp
    No.......... different OD size center mains..
    Feb 2005
    Is there another spot to separate it off the Bridgeport that will work or this project is over!!
    Thanks
    Jun 2012
    Indiana
    Have read where Jeff Dunn has machined the 2.4 front half to fit the 2.5 small bearing stuff, but dont know that info first hand.
    TX......somewhere?
    Quote Originally Posted by capteliminator View Post
    saw a pic of it on fb.. aligned bored?.. looks like it takes a lot of "meat" away at case bolt holes?.. looked really thin.. cost efficient?.. donno?
    Jun 2012
    Indiana
    Yeah im not sure either, just passing along the info. I assume with the difficulty of finding a small bearing 260 front half this would be another alternative, if it works!
    TX......somewhere?
    I've always had a hard time with usin' mis-matched case halves on real stem winder motors anyway.. jus can't see tha 2.4 to a 2.5 being worth a $hit for bein' very trustworthy for a bunch of expensive parts............ jmo.
    Feb 2005
    Thanks for the info....That's just what i wanted to know. I will keep my eyes open for a 260 front half
    ttopp
    Aug 2011
    ct
    I have a 2.4 efi front half that Jeff Dunn modifed to fit a 2.5, the reed plate and horn with ecu bracket I would sell to you. Thanks mark
    Feb 2005
    if i put the horn you have or a horn from a 260 will it be a 260 or are there other differences in the block? I can understand the wiring harness will be different, but what else?
    Aug 2011
    ct
    Block is all the same. 260 was efi and 245 was carb version. You will need an ecu and the efi harness
  12. #12
    Feb 2005
    pm sent
  1. Mercury Tech: Need Help! Carb Swap on '95 175 Merc
    By full monty in forum Technical Discussion
    Last Post: 08-27-2012, 07:59 AM
  2. Mercury Tech: Merc. carb swap
    By rdkvector in forum Technical Discussion
    Last Post: 02-06-2011, 09:55 AM
  3. Carb swap on 90 HP inline 6 Merc
    By rideordie in forum Technical Discussion
    Last Post: 02-01-2011, 04:42 PM
  4. merc carb and cooling problems( powerhead swap)
    By Will I Am in forum Technical Discussion
    Last Post: 05-22-2007, 08:03 AM
  5. 1987 Merc 220 EFI swap to CARB?
    By hawktuner in forum Technical Discussion
    Last Post: 04-05-2006, 09:21 PM
