Results 1 to 3 of 3
Thread: 3.0 crank
01-11-2018, 11:55 AM #15000 RPM
- Nov 2003
- n.c.
- 301
- 25
3.0 crank
are all 3 liter optimax cranks the same?
28 SS
01-12-2018, 09:53 PM #2
no, the earlier ones had 2 rows of loose bearings per main versus the new style which have a caged bearing.
01-12-2018, 10:09 PM #3Supporting Vendor
- Sep 2006
- Key Largo, Fl
- 3,274
- 215
- 30
- 585
And the very early ones had eight splines instead of 13, Chris
New Big bearing 2.5 crank (not a 260 style crank)
By GILMORE010 in forum Misc. Parts and AccessoriesReplies: 2Last Post: 02-24-2016, 03:32 PM -
drag crank,has a coller or spacer between bearing and crank is this normal?????
By camaro7081 in forum Technical DiscussionReplies: 29Last Post: 10-22-2009, 09:42 PM -
what is the difference from a 260 crank to a fishing motor crank
By camaro7081 in forum Technical DiscussionReplies: 21Last Post: 02-14-2007, 08:20 PM -
Top Main Crank Bearing/ Rod To Crank Bearings
By mr twister in forum Technical DiscussionReplies: 2Last Post: 09-09-2003, 08:45 AM
