Results 16 to 30 of 45
Thread: Looper head studs
01-12-2018, 04:03 AM #16Screaming And Flying!
- Jun 2007
- Singapore/Melbourne/Italy
- 9,096
- 1008
- 354
- 4296
- 1950
- 7 Post(s)
stainless stretches that why head bolts are always steel
Captain75 thanked for this post
01-12-2018, 02:33 PM #177000 RPM
- Central Florida
- 2,643
- 37
- 32
- 219
01-12-2018, 05:01 PM #18
01-13-2018, 06:51 PM #197000 RPM
- Central Florida
- 2,643
- 37
- 32
- 219
If you just want to save any wear from running the bolts in and out then I know some people use the Dorman 675-094 which is zinc plated and easy to find as auto parts or Amazon, ebay, whatever. It only has 5/8 inch of threads on the block end. I don't know of any double ended stud off the shelf that engages all the threads. And don't know where you would find high strength stainless allthread or setscrews as a catalog item.
01-15-2018, 08:43 AM #20
01-15-2018, 09:02 AM #21Screaming And Flying!
- Jun 2007
- 9,096
- 1008
- 354
- 4296
- 1950
- 7 Post(s)
you need the opposite of that thread I would have thought
01-15-2018, 09:29 AM #227000 RPM
- Central Florida
- 2,643
- 37
- 32
- 219
01-15-2018, 10:07 AM #23
01-15-2018, 11:41 AM #24
powerabout liked this post
01-15-2018, 11:58 AM #25
Set up studs.. never thought of looking at those, their usually 3/8, probably work fine... I just looked at msc industrial, they have some in 5/16 that are 2 1/2 long probably work good and they look like they have rolled threads and are made from stressproof steel which is very strong...I know they use that on bolt together hydraulic cylinders that have the long studs on the outside..Dave
01-15-2018, 12:10 PM #26
I use McMaster all the time and have never been disappointed in the quality products they sell , I see their less expensive than the msc . opinion only but I would rather use coarse nuts than lower strength studs material..I see they also have grade 8 threaded rod too which is usually rolled.
racer, BarryStrawn liked this post
01-16-2018, 02:40 PM #277000 RPM
- Central Florida
- 2,643
- 37
- 32
- 219
Agree that if black oxide coating is acceptable then the setup stud is better than the Dorman stud.
And grade 8 threaded rod would be better than the setup studs if you don't mind doing the cuts.
01-25-2018, 04:48 PM #28
Anyone tried reboring to use 3/8” / 10mm?
seems to be enough meat!?
01-25-2018, 06:47 PM #29Screaming And Flying!
- Jun 2007
- 9,096
- 1008
- 354
- 4296
- 1950
- 7 Post(s)
the F1 v8 is 3/8, same bolt pattern
01-26-2018, 03:14 AM #30
Ok, got it!
I must say I’m a bit tempted, mainly because I’ve got a fair amount of high grade m10 studs/short rods...
At the same time I’m a bit afraid of messing things up when boring.
If, I should go ahead with the 3/8 or m10 Idea, I need to come up with a boring method that makes sense. I dont want to use the mill, since It takes so much time to set up the block.Last edited by Captain75; 01-26-2018 at 07:51 AM.
head studs
By bildit4u in forum Technical DiscussionReplies: 38Last Post: 02-28-2008, 05:59 PM
