Results 1 to 13 of 13
Thread: Merc V6 Pistion mods
01-09-2018, 08:43 PM #15000 RPM
- Oct 2015
- Kentucky lake
- 480
- 31
- 15
- 60
Wanting to do as much to my spare merc 2.0 as possible. . Its a non finger ported engine , if i square cut the pistions for better flow, will it hurt anything by doin that being its not finger ported. Wat do the finger ports do ?
01-09-2018, 08:46 PM #25000 RPM
- Oct 2015
- Kentucky lake
- 480
- 31
- 15
- 60
I see this mod alot on pistions but they all have finger holes added or sloted just want to make shure the two doin have to go together
01-11-2018, 07:16 AM #3
You can clean em up but don't drill the extra holes.....
01-11-2018, 08:08 AM #4
01-11-2018, 08:32 AM #5
Can anyone say , one good thing about the piston on our right ... ?
# 1 )
Can you name three reasons why the same piston is now ruined .. ?
# 1 )
# 2 )
# 3 )
01-11-2018, 08:39 AM #6
rock, hydrostreamvking4m liked this post
01-11-2018, 09:06 AM #7
You didn't do it? It will still yet be polished down to remove the bit marks
01-11-2018, 06:25 PM #85000 RPM
- Oct 2015
- Kentucky lake
- 480
- 31
- 15
- 60
01-11-2018, 11:21 PM #9
01-12-2018, 09:00 AM #10
Perhaps "ruined" is too harsh of a word . Any time the thrust face is compromised it puts more of the load on the remaining tabs . As the tabs collapse the piston will rock to a greater angle in the bore and lift the rings off the bore .
If the "excessive lead in" area is in the way of flow , then either remove it entirely or come to grips with the fact that by the time the piston is approaching BDC that "the party" is over with . And whatever air is still being push/pulled will move a lot less turbulent with a blunt ( front of a wing ) arbor , than a sharp edge .
The reverse "cowcatcher" . Notice how the piston has a cut at the base to shear fluid off the cylinder walls . They do that so excessive fluid won't pile up in front of the ring and lift it off the bore . Rings have a tough enough job , no sense in asking them to be wind shied washers too .
Probably the worst effect of all is that you are packing the cold side with raw fuel and shearing on the hot side . I really don't need to explain what happens when you purposely load the piston against the hot side wall .... do I .
01-12-2018, 01:37 PM #11
Thanks for your opinion on this matter Chaz, as always I respect your input. So you agree with my angle on bottom part of the piston as a scrapper, but not the port opening angle? I had another old buzzard that I have a lot of faith in and have learned a lot from over the years that showed me that mod . Now I gotta sit and think and analyze which one of you I wanna go with.
I have been running this setup ever since I've been hot rodding , and ain't never had a piston failure in this area yet and as long as I don't scatter one don't have premature ring failure. But, a very interesting take on the subject, and thanks for your input
rock liked this post
01-12-2018, 01:57 PM #12
There's always more than one way to skin a piston
FORBESAUTO liked this post
01-12-2018, 09:10 PM #13
I didn't look hard enough to see the "scraper" . You must have had me mesmerized with the Moollllleeeeeee .. err ... cowcatcher ..
https://media.giphy.com/media/rL8inqijmKECs/giphy.gif
But now that I had time to look , yes , I do all my pistons that way .
Pistion ?
By markdawson38 in forum Technical DiscussionReplies: 4Last Post: 08-21-2014, 08:06 AM -
pistion help
By Tripps in forum Technical DiscussionReplies: 1Last Post: 09-18-2010, 08:58 PM -
Pistion weight
By Tripps in forum Technical DiscussionReplies: 3Last Post: 01-11-2010, 07:42 AM -
Oddball Pistion
By KeithRichards in forum Technical DiscussionReplies: 4Last Post: 02-05-2002, 08:17 AM
