Results 1 to 15 of 31
01-08-2018, 07:56 AM #1
Anyone used JB weld on an intake manifold reed side?
Will the JB weld hold up to the job ?
I need to fill in some of the intake path (the reed cage side) Will the JB weld do the trick ?
I dont want parts of it coming off and getting stuck in the reeds.
01-08-2018, 08:50 AM #2
I use splash zone epoxy due to ease of filling and shaping. But it's a little pricey for 1 job. I know T-Rex used to use pig putty. What ever you use make sure to rough up the surface, make sure it's clean, and knead the initial coating into the roughed up area to make sure has good adhesion. Make sure whatever you use will hold up and not break down to fuel (I know JB will turn to a rubbery substance with transmission fluid, not sure how it holds up to gasoline)
01-08-2018, 09:15 AM #3
JB Weld a Harley Davidson Sportsters best friend
01-08-2018, 10:23 AM #4
01-08-2018, 10:53 AM #5
If ya decide to use splash zone, let us know and I'll give ya some pointers on mixing and application so itll be easy to work and hold up extremely well
01-09-2018, 02:09 PM #65000 RPM
- Sep 2008
- Mass
- 450
- 16
- 39
01-09-2018, 02:39 PM #7
Heres an oil pump void I filled in with it. When you mix it up, you need to do it with as little water as possible so that tiny voids will not be left behind when the water dries out causing it to be weaker. Rub a thin layer into the metal until it adheres and does not roll up of of surface any longer to assure it has good penetration. Once foundation is on you can build it to the shape you won't. Then wet your hand with water and shape it and smooth out however you like. Almost like working pottery, I swear I could make you a bowl out of the stuff. You can work it down to where you won't even have to file or sand it. It also has enough consistency to it it don't make a mess and run all over the place.
hydrostreamvking4m liked this post
01-09-2018, 03:04 PM #8
01-09-2018, 06:56 PM #95000 RPM
- Aug 2007
- Gravenhurst, Ontario.
- 708
- 50
- 42
- 199
- 210
I used JB weld to patch a front half.
worked fine, no issues.
cleaning, prep etc is critical.
01-09-2018, 11:28 PM #10
01-10-2018, 02:40 PM #11
Ironcrete, used it to repair a bad gouge in a Ford 300 6 cly. Wrist pin came loose, used ironcrete to repair the cylinder. Took it down about 24,000 miles later for a valve job, repair intact - still showed my hone crosshatch. Used to swear by marinetex or devcon, not anymore!
AIRWALK
gettin' old ain't for sissies
01-10-2018, 04:11 PM #12Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
That's good stuff but overkill?
01-10-2018, 06:13 PM #13
01-10-2018, 06:42 PM #14Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
Not overkill for your cylinder, the stuffing.
01-10-2018, 07:03 PM #15
Gotcha, but gas, oil etc. doesn't affect it. Stood up to heat & vibration well - plus it stayed put under fairly extreme conditions. I would want the best option inside an engine, considering the possible consequences. I would have overkill than overhaul.
AIRWALK
olboatman liked this post
F-1 intake manifold
By racer in forum Misc. Parts and AccessoriesReplies: 1Last Post: 06-23-2014, 08:03 PM -
gm 350 intake manifold
By sarantis in forum Jet Boats, V-Drives and Stern DrivesReplies: 1Last Post: 08-24-2010, 09:31 AM
