Results 1 to 15 of 64
Thread: Sportmaster Carnage
01-03-2018, 09:06 PM #1
Sportmaster Carnage
So I bought a 2.5L Sportmaster case and 15" mid at Jasper. Don't have a powerhead yet, so I mounted it to my Mirage, rolled it in my garage, and forgot about it. Turns out the brutal cold weather in the Midwest dropped the temp in my garage to 28* New Years night. I was out in the garage looking at things when I noticed the rear seal was pushed out. I then looked around the starboard side to find the case split and ice sticking out. After putting a space heater under it to thaw things out, turns out there was ZERO oil in it and over 20 oz. of water.
Yes, I should have changed the fluid before winter. However, would anybody really expect a fellow boater to sell you a case with 100% water in it? I was initially numb. Now I am pissed! Not one oz. of oil. Not one! It is really hard to trust buying used parts. 😔
01-03-2018, 09:11 PM #2
I'd be pissed too, but rule of thumb on gearcases, check the oil before you buy or if it's shipped to you, check the oil as soon as you get it................. Still, seller needs to step up to the plate on this one.
NICE PAIR, RIVERRUMMER 70 liked this post
01-03-2018, 09:33 PM #3
The caliber of racer and people in general at Jasper you would never expect to have something like that occur or be sold in that condition. Just goes to show you gotta check always. Was there any conversation with the seller on when oil was changed or if in fact it was drained. Just curious if you were lied to.
01-03-2018, 09:56 PM #4
01-03-2018, 10:00 PM #5Screaming And Flying!
- Jun 2007
- Singapore/Melbourne/Italy
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
I only buy gearboxes in bits after buying from reputable people who clearly didnt know what the inside looked like
W2F a V-King, Cervelo777 liked this post
01-03-2018, 10:15 PM #6How do you lose 100% of the oil?
01-03-2018, 10:25 PM #7
The outer prop shaft seal is pretty much baked, it the spring still in it?
01-03-2018, 10:38 PM #8
Very possible it pushed all the oil out and filled with water without him knowing. Obviously he should’ve checked before he sold it.
'95 STV "The Blue Goose"
01-03-2018, 11:00 PM #9
01-03-2018, 11:05 PM #10
I know that, is the spring still in the seal and is the lip surface burnt off?
01-04-2018, 08:19 AM #11
Man that Really Sucks... Unfortunately why you have to always pull the plug...drain some oil and look for water and chunks on the plug when buying used. I don't even like to see a clean plug and new oil in one when i buy am buying a used case.. usually makes me suspicious. I would rather see how its been running. Bad situation no matter what. Dave
01-04-2018, 09:54 AM #125000 RPM
- Dec 2012
- tn
- 686
- 17
- 46
01-04-2018, 10:03 AM #13The Historic Photo Master
- Jan 2004
- Florida
- 37,836
- 64
- 1667
- 337
- 19218
- 3 Post(s)
Also unfortunately...everything inside is probably rusty too, and not much to rebuild with. Sucks.
01-04-2018, 10:50 AM #14
01-04-2018, 10:52 AM #15
Bridgeport locator pin carnage :(
By pyro in forum General Boating DiscussionReplies: 227Last Post: 07-05-2015, 11:26 PM -
todays carnage
By gary slagle in forum General Boating DiscussionReplies: 10Last Post: 09-23-2012, 11:11 AM -
Mercury Tech: 1989 2.0l 150 Flywheel Magnet carnage
By Whitebeard in forum Technical DiscussionReplies: 4Last Post: 07-27-2011, 10:16 PM -
Sport Jet gearcase carnage
By ProdriveMS in forum Technical DiscussionReplies: 0Last Post: 09-09-2009, 06:52 AM -
Season's over, ouch name that carnage.
By Hydrophobic guy in forum General Boating DiscussionReplies: 24Last Post: 09-19-2008, 02:38 PM
