Results 1 to 4 of 4
    Bayville, New Jersey
    throttling twins
    Last season I removed the throttle return springs on both motors since the boat had a dual hand throttle which would creep back unless I kept a hand on them.
    I want to install a split foot throttle and use a single hand throttle to over ride it for cruising. Will having the foot throttle necessitate re installing the return springs ?
    If so how do I eliminate the hand unit creeping back from the spring pressure? Does anyone have their twins set up like this, and if so are there any concerns or
    drawbacks to doing this ?
    Aug 2009
    mpls,mn
    There should be a throttle tention adjuster on it?
  3. Thanks berdes thanked for this post
    Foot throttle will need return springs, once you have a foot throttle you wont use the hand throttle. Land & Sea made a combo foot throttle and return spring is needed.
  5. Thanks berdes thanked for this post
    Dec 2001
    HeeHee this one is so good......more power scotty.....the early....198000s binical had a screw that did the tenson. Where we are going..... no need for choklite...
  1. Alarm going off when throttling up on Mercury
    By blowitup in forum Technical Discussion
    Last Post: 06-01-2016, 06:08 AM
  2. Deep Vee With Twins vs Cat With twins vid
    By Donat in forum General Boating Discussion
    Last Post: 01-31-2006, 11:05 PM
  3. Can I Run Twins???
    By Hottrucks in forum Props, Setup, and Rigging
    Last Post: 03-29-2004, 04:13 PM
  4. Toe in or out with twins ??
    By pantera1 in forum Technical Discussion
    Last Post: 04-21-2003, 02:50 PM
  5. Twins
    By vishus in forum General Boating Discussion
    Last Post: 03-21-2003, 11:46 AM
