Results 1 to 10 of 10
    Sep 2012
    What prop is this?
    Any one have a clue what brand of prop is this? What application is it best used for? Anyone running one and what is your setup?
    Thanks!
ID:	396082   Click image for larger version.
    Cleaver prop. Used for stern lift and top end speed on a very light hull. Poor holeshot.
    Dec 2001
    15hp champion outboard......or ssm outdrive.....
    Sep 2012
    Thanks for the replies so far. I know it is a cleaver, and im figuring it is a 26 pitch. just wondering if someone knew the brand.
    Kiekhaefer AeroMarine/Mercury(if thats a little "K" embossed at the base of that one blade) for TRS Sterndrives, 1'' shaft "Sport Cleaver". Produced by Mercury in the 70's and into the 80's. Its been reworked slightly, possibly by Mercury, after it was tested on the customers boat, to dial it in better, for his application. When you hit something, the MercTrans or Borg-Warner 72-C transmission, ahead of the TRS drive, could intentionally slip momentarily, saving prop and/or propshaft damage. Hence, the solid hub prop design for the TRS.
  8. Likes Star1 liked this post
  9. #8
    Sep 2012
    Amazing. Thank you FUJIMO for your wealth of knowledge.
  10. #9
    Quote Originally Posted by Turborr View Post
    ...You betcha... By the way, never use these props on an outboard. Don't even bother testing with them on an O/B. Can be costly.
  11. Likes NICE PAIR liked this post
    Sep 2012
    Warning taken. I love my challenger and my 300xs too much be playing around with danger. It did cross my mind to try it out though.
  1. OMC Tech: Help! 225 carbed Johnson melting prop hubs / high exaust temps through prop hub
    By Tunnelvision1995 in forum Technical Discussion
    Last Post: 09-12-2017, 08:03 PM
  2. Prop slip on overhub prop related to no exhaust relief?
    By B.Mac in forum Technical Discussion
    Last Post: 10-06-2015, 03:25 PM
  3. which 4 blade prop do you recommmend for my super boat prop
    By great adventure in forum Props, Setup, and Rigging
    Last Post: 10-07-2013, 10:14 AM
Spinelli Props
