Results 1 to 15 of 16
    Sep 2014
    chicago,il
    1990 johnson 200 inner exhaust housing replacement/breakage
    2 part question..
    1- the inner exhaust housing on my 1990 johnson 200 gt developed a "hole" in the upper part , about the size of a quarter/half dollar. dont know why but all the pieces were sitting on the water pump. im thinking this may be why my power was down???? anyone seen this before?
    2-looking for a replacement. the "exact" housing per omc is different than say a later one from a 92+.........the 92+ ar eway more common and much cheaper. anyone know if they will swap? any benefit to a newer one? they run different part #s so there somne difference?
    Aug 2009
    mpls,mn
    Any damage to the powerhead? sounds like high exhaust temp to me?
    Sep 2014
    chicago,il
    no damage that i can see...engine was running ok..compression still even...
    Jun 2009
    central minnesota
    what did the pump look like
    Aug 2009
    mpls,mn
    for a 20inch motor 1990 part # 0338598 / 1993 is 0338597 one number off so they changed something and the cast is like 100.00 more but not availabla new?
    Sep 2014
    chicago,il
    yes, i fgound them new still.. the $100 is the real question.. if i dont have to dump 100 for the same part??????????? pump started to melt, or at least the upper housing. last time out water pressure was 30+psi at wide open
    Aug 2009
    mpls,mn
    were the pieces on the pump melted alum?
    Aug 2009
    mpls,mn
    On ebay the 93-05 is dirt cheap only one for a 88-92 is 200.00 just get yours welded back up for squat .jmo
    Sep 2014
    chicago,il
    [No. More like chunks,bits,pieces. No signs of melt
    QUOTE=racervboat;3011206]On ebay the 93-05 is dirt cheap only one for a 88-92 is 200.00 just get yours welded back up for squat .jmo[/QUOTE]
    Sep 2014
    chicago,il
    I don't care to wrld,rather get new. Dusky has it new for 130...90...was thikng maybe 93 +better?????power????
    Aug 2009
    mpls,mn
    looks like it won't fit ? diff part #s don't know for sure the diff.
  12. #12
    Sep 2014
    chicago,il
    Don't know if it will fit. Don't wanna break it down, buy a part and find out hard at it don't fit. I'll just get the new one from dusky. I'm more concern wht i got a hole
    Quote Originally Posted by racervboat View Post
  13. #13
    Aug 2009
    mpls,mn
    Exactly what im saying why is there a hole in it?
  14. #14
    Sep 2014
    chicago,il
    I don't know. Kinda reason 4 the post. I. Not an engine guru
  15. #15
    Aug 2009
    mpls,mn
    Can you show a picture or is it still together?
  1. Replies: 10
    Last Post: 11-10-2011, 11:07 PM
  2. OMC Tech: 1990 johnson 225 powerhead to a 1994 johnson 150 midsection??
    By 85HYDROSTREAMVECTOR in forum Technical Discussion
    Last Post: 03-02-2011, 08:20 AM
  3. Trim Pump Housing Bushing Replacement Questions
    By Propster in forum Technical Discussion
    Last Post: 12-04-2001, 03:29 PM
