Results 16 to 18 of 18
01-07-2018, 08:32 PM #16
I'm not affiliated with this company, but MasterTech Marine in Milton FL offers a dual diaphram pump to replace vro pump that looks real nice..... If I had not already installed the carter p4070 at my Tank I would have tried it out. A bit pricey @$168, but if you want to stay with a pulse type pump, Looks like an answer many people are looking for. On another
topic, do any of you guys that run elec. pumps on outboards get any flack from the law, or coast guard? I got a Mechanic around here that said I'd get a HUGE fine for gong elec. I have it coming off the key switch through my safety cut off switch to a relay powering the pump.
01-07-2018, 08:39 PM #17Screaming And Flying!
- Jun 2007
- Singapore/Melbourne/Italy
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
you have a pressurised fuel line inside the boat, the USCG doesnt like that.
Hence all the non race outboards have the vst setups on the engine.
I am not sure of what your insurance company would make of that.
oldschoolnc thanked for this post
01-09-2018, 08:52 AM #18
It is a hydrostream Drag set up. Looks like I'm not the only one with the pump in the boat. Also I'm on a small lake/river system in the sticks, haven't seen the law on the water since I moved from Ft. Lauderdale FL 15yrs ago. There you get three safety inspections from three different agencies between the ramp and the ocean....I was just curious if the guys who run in those heavily regulated areas had problems..... But thanks for your comment.
1989 evinrude xp200 electric fuel pump
By mike1 in forum Technical DiscussionReplies: 5Last Post: 12-17-2007, 10:48 PM -
Installing Electric fuel pump on Looper, do I need to remove the VRO Pump?
By imq707s in forum Technical DiscussionReplies: 6Last Post: 05-12-2005, 02:21 PM -
electric fuel pump, through factory pump, or by pass?
By WATERWINGS in forum Technical DiscussionReplies: 6Last Post: 06-02-2003, 11:38 AM -
Electric Fuel pump-vs- stock pump
By B.Mac in forum Technical DiscussionReplies: 29Last Post: 10-11-2001, 03:49 PM
