Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 31
    Aug 2012
    beaumont, tx
    labbed vs. non-labbed ET
    im a lil confused on what merc is actually selling. specifically with their ET's .....on the merc HP website....they show the ET coming in a lab finish. they dont show a pro finish unless im missing it. if you look at a ET #48-849246L62 on the box its labeled "lab" finish. but im thinking this is the standard ET. Priced around 950-980 depending on dealer. i did see merc offered a "doubled lab" finish....is this what people are considering Labbed prop?
    does anyone have a different part number for a standard or labbed in same degree (just used a 26 for sake of it)
    was told the actual "labbed" prop cost is around 1400$?????
    whats the scoop
    Jul 2013
    With that "L" in the part number it is a labbed prop. Never heard of "double labbed" from Mercury, but that's just me and I'm going from how it was many years ago. Things could have changed.
    One other thing, the "L" part number should be stamped on the prop and an engraved serial number for the lab work.
  3. Likes texasvector liked this post
    Aug 2012
    beaumont, tx
    this is one parts list.....all are labeled labbed....Click image for larger version.
    all props ive seen lately have the L in part #.....but ive seen other props that were clearly "labbed more" with same part #
    i know theres supposed to be 2 versions and im just trying to firgure out how to tell factory differences by number or label .......looking at prop u can see difference easy
    Aug 2012
    beaumont, tx
    i dont see part number in book without the "L"
    Feb 2005
    Muskoka Canada
    I’ve always called props that came from be lab the first time “lab” and if you sent it back to
    tje lab for changes that would be double. Right or wrong, that’s how I did it
    2023 TUFF 25
  7. Likes tux974, Dave Strong liked this post
    Aug 2012
    beaumont, tx
    Quote Originally Posted by RBT View Post
    thats how im reading it on the site ROB.... "double labbed" do they stamp the prop if they re-work it? do they work all props the same second go round?
    do they even offer an ET that hasnt been to the lab at all? or they all ran through there once? seems like all the ETS purchased now have "lab finish" on label
    Jun 2001
    Cromwell. NEW ZEALAND
    A labed prop as sold n the box is a final exact or blue printed prop. A double lab is a prop reworked by merc to suit a customers rig and has a serial number stamped into it. If that prop is damaged or replaced then merc has the info from the serial number to repair or replace it.
    Popey
  10. Thanks texasvector thanked for this post
    Likes RBT, Capt.Insane-o, wicheckmate, tux974 liked this post
    Aug 2012
    beaumont, tx
    steve...are all ET's sold new as labbed props?
    I had some older labbed ets and they all broke. A non lab 28 is the lone survivor.
    Belgium
    And because there is no L number in it it is a non labbed prop?
    Are the labbed et's that much thinner and due to that prone to cracking?
  14. #11
    Aug 2012
    beaumont, tx
    Quote Originally Posted by bigboy View Post
    where is the part number without a "L".........
    capt.......whats the part number on the 28?
    May 2009
    Ormond Beach, Florida
    I don’t know the entire history of the Mercury prop “Lab” but I do know it wasn’t until the late 90’s that they offered these services to the general public. In this timeframe you would contact “the lab” directly, discuss your application and they would either take your Mercury prop or pull one out of stock and blueprint it to the specifications they arrived on based on your discussion with them. It was an additional service and billed separately, I.e. they didn’t sell you a prop, just a service.
    Aparently they realized there was money to be made selling a blueprinted prop and hence the out of the box “labbed” props being sold today with unique part numbers. For some of the high performance props like the ET it’s the only prop on offer. For others like the ProMax they offer a standard and labbed version. I imagine they looked at what was selling and made the decision to only offer some models as “labbed”.
    Today a labbed prop simply means its blueprinted to the exact specs of the props original design, in the past it meant a custom prop worked to your specific requirements. I believe they still offer the custom service but you would probably want to buy a non labbed version, if it’s available and send it to them with the specs you arrive at based on a discussion with the lab. Doing a prop this way will result in a more expensive prop but it will be custom tuned to your application. I wouldn’t start with a production “labbed” prop in this scenario since a lot of metal has already been removed giving them much less to work with.
    Mark
  16. Likes texasvector liked this post
    Quote Originally Posted by texasvector View Post
    My Labbed 28 part number is, 48-849248 L62
  18. Likes texasvector liked this post
  19. #14
    It's in my shed undergoing cryo treatment so not off hand.
  20. #15
    Jul 2013
    Now thats funny!
  1. WTB- Labbed promax 28 or labbed pro ET 28
    By dogeatdog in forum Propellers Wanted
    Last Post: 10-16-2017, 06:57 AM
  2. Labbed 31 SRX
    By CUSTOM PERFORMANCE 1 in forum Propellers
    Last Post: 05-05-2017, 03:05 PM
  3. Mercury Labbed Bravo1 vs BBlades Labbed Bravo1
    By PORT in forum Props, Setup, and Rigging
    Last Post: 12-30-2016, 06:53 PM
  4. Replies: 1
    Last Post: 11-30-2016, 07:01 PM
