Page 3 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 31 to 45 of 67
  1. #31
    Feb 2016
    Nags Head NC
    I'm pulling the coned lower unit on my 89 Merc 150. I'm getting water and more metal in the oil than I care to see even after changing the oil twice through the season. Could any of you gentlemen direct me to any useful threads? This will be the first time I've been into one further than the water pump.
  2. #32
    minocqua, wis
    Water and oil ,metal not good ,by the time you get manual and tools needed you might be better find local shop have look inside first
  3. Likes WillySteve liked this post
  4. #33
    Winch stand/ ladder/ hand rail installed.
    4 point tie downs installed.
    Bracing installed/welded.
    Total time for this part of project: 2 weeks
    1st day ... planning
    2nd day ... 1/2 day trying to remember plan, drawing plan.
    3rd day ... pickup materials, cut to size.
    4th day ... layout, drill, fit back 1/2, weld back 1/2.
    5th day ... layout, drill, fit front 1/2, weld front 1/2.
    6th day ... cleanup horrendous mess.
    Rest of 2 weeks was spent recuperating ... Old guys shouldn't do this stuff.
    Next: get the boat off and start prepping for paint. ... Yay!
ID:	396160   Click image for larger version.
ID:	396161   Click image for larger version.
ID:	396162   Click image for larger version.
ID:	396163   Click image for larger version.
ID:	396165   Click image for larger version.
ID:	396166   Click image for larger version.
  5. Likes WillySteve, Dan sos express liked this post
  6. #34
    Jun 2008
    Sardis Lake Oklahoma
    Spring pads measured and welded today....just to find that I'll have to move a crossmember!
    When I measured I forgot about the center bellcrank, being 6" wide where the spring eyes attach and the extra 3" put my front axle right on a crossmember.
    NEW Plan....move that crossmember forward and add another across from the bellcrank pads!!
    It's just a thang.....nothing a little primer and paint won't cure!!!
    WillySteve Hendricks
    20XDC Bullet/Modified Merc 260
    295TF Charger/ProMax 225x-Sold!
    '83-20' Contender Pickle Fork/Merc 2.4 ModVP BridgePort EFI-Sold!
    '85-18' Stratus STV/Merc Hi-Po 2.4 EFI-Sold!
    Freedom 240 DLX Fisher Toon/Merc 115
    10' Cougar Cub/Merc 25HP On The Bottle!
    18" Home Made Tunnel/OS .021XM Outboard on 50% Nitro and Expansion Chamber
  7. Likes NICE PAIR liked this post
  8. #35
    Jun 2008
    BTW....Awesome job NP and yer right.....When you get so old you gamble on forgetting sum'a the little things!!!!
  9. #36
    Quote Originally Posted by WillySteve View Post
    The scary part is if I got stuck in there and somebody called 911, they might cut up my boat to get me out. ;-)
  10. Likes WillySteve, FORBESAUTO liked this post
  11. #37
    Aug 2015
    North Carolina
    My winter project is to install this motor on this boat. Boat is in my garage. Motor should ship tomorrow. Plan to put the seats on sliders so my vertically challenged friend can drive some. Move the gas pedal back some for more knee clearance under the dash. Fix a few little nicks on the hull bottom and sides. Looking forward to some warmth so I can see how it runs. Hoping the 200XS will push it 85 or so. We'll see. Only my second high performance boat so I'm learning as I go.
ID:	396227   Click image for larger version.
Name:	rt side frt.jpg
ID:	396228   Click image for larger version.
ID:	396229   Click image for larger version.
  12. Likes WillySteve, NICE PAIR, mrichartz liked this post
  13. #38
    Jun 2008
    Nice!!!!
    I'm sure it'll blow by 85 once set up!!!!
  14. #39
    Aug 2015
    NE Tennessee
    Quote Originally Posted by DangerNewb View Post
    For your vertically challenged friend... T-H Marine makes a hot foot mounting plate that allows the hot foot to be slid forward
    or back. About $50-60..
    http://thmarine.com/hot-foot-slide-mount#!prettyPhoto
    James H.
    If con is the opposite of Pro, is Congress the opposite of progress?
  15. Likes WillySteve liked this post
  16. #40
    Aug 2015
    North Carolina
    Quote Originally Posted by W2F a V-King View Post
    Nice to know. Thanks. I need to move the seats anyway to allow my knee/upper shin to not hit the bottom of the dash and already bought the seat sliders. They were about the same cost each as the hot foot slider so not too bad.
  17. #41
    Aug 2015
    NE Tennessee
    So I have a new project, and since it just happened....it's now my "winter" project.
    My wife was coming home from work, and a 17 yr old girl ran a red light and turned left in front of my on coming wife in her Lightning.
    Whats sad is the cost to repair it is about 9K. 75% this cost is replacing, repairing the SRS (air bag system) and getting operational with new stuff. Both bags blew off.
    So once I get it home the fun begins....it's to cold to finish the glass work and start painting the boat anyway....
    I'm just thankful my wife did not get hurt bad. The young girl lost her license for 1 year. This was her 3rd wreck and 2nd ticket in the year or so she has been driving....
    I'm all about doing "Honey Do's" ....
ID:	396325 Click image for larger version.
ID:	396326 Click image for larger version.
    James H.
  18. Likes NICE PAIR, WillySteve liked this post
  19. #42
    Aug 2014
    Crescent beach
    Hi There! Just pulled home a 16.5 Larsen Senza out of a snowbank for my winter project! Seems to be in nice clean shape overall, but its gonna need some work on the powerhead (Johnson 140). Owner gave up, and now its my opportunity!
    no pics yet!!
  20. Likes WillySteve liked this post
  21. #43
    Jun 2008
    We live in Deer country and 6 years ago I hit one in my Navigator. I was skidding and prolly only doing 10mph on impact!
    The airbags did not deploy but the cost was still almost 6k.
    We now are protected for front end body damage on our Lincoln, Ranger and '68 F-100:
    The Ranger my son & I fabricated in my shop!
ID:	396335 Click image for larger version.
ID:	396336 Click image for larger version.
  22. Likes NICE PAIR liked this post
  23. #44
    Aug 2015
    NE Tennessee
    [QUOTE=WillySteve;3012299]We live in Deer country and 6 years ago I hit one in my Navigator. I was skidding and prolly only doing 10mph on impact!
    We now are protected for body damage on our Lincoln, Ranger and '68 F-100:
    /QUOTE]
    Yes, I know what your saying, about not having to be going fast to sustain $$ Damage. The speed limit on that road is 35 mph and my wife does not speed (at least I don't think so ) And that truck Will speed easy.... But she stood on the brakes and the ABS kept her from sliding and slowed her down before she hit.
    I forget what the actual threshold is for the air bags to deploy from the inertia change or from speed to stop has to be XX before they deploy. You were lucky the deer didn't cause those to inflate.
    Wonder what a cow catcher would look like on a Lightning ? We have deer in our area as well.
    James H.
  24. Likes WillySteve liked this post
  25. #45
    May 2014
    Miami
    Converting a 31' sonic to outboard engines. Redid the cabin upholestery extended the cockpit, rewired the console with new gauges and am now replacing the gas tanks. Hope to have tanks done by end of month then I can put bench seat across the back. Have an aluminum bracket and put a pair of merc 250 Efi on the back. Can't wait to give her a run.
  26. Likes WillySteve, NICE PAIR liked this post
  1. The winter project
    By Cobra1racer in forum General Boating Discussion
    Last Post: 09-28-2008, 10:29 PM
  2. Need y'alls prayers please!
    By CDave in forum The Scream And Fly Lounge
    Last Post: 12-25-2007, 01:54 PM
  3. Who Wants a winter project
    By marshan162 in forum The Scream And Fly Lounge
    Last Post: 11-06-2006, 01:47 PM
  4. What's Your Winter Project??
    By Instigator in forum General Boating Discussion
    Last Post: 11-18-2003, 04:59 PM
  5. My Winter Project
    By speedyfast in forum General Boating Discussion
    Last Post: 04-09-2003, 09:30 PM
