Results 1 to 3 of 3
    Nov 2004
    LEBANON OREGON
    200 opti sport jet losses rpm after 6-10 seconds
    at WOT gets 5700 rpm for 6-7 seconds then drops to 5000
    cleaned injectors
    new reeds
    gone thru compressor
    checked tracer valve, regulators etc
    fuel pressure 95/105
    air pressure dead headed 128 psi
    cleaned air injectors fuel injectors replaced 1 cyl that tested low flow
    fuel pumps test good
    has spark on all 6
    swapped crank sensor with known good
    can cyl drop test at speed no effect on cyl 5 or 6 above 3500 rpm exept within first attempt at WOT where its holding 5700 before it falls to 5k
    cyl 6 has the new set of injectors and has been issue since beginning..
    missing something seems sensor or electrical as mechanicals are sound running out of ideas here
    May 2001
    Ga
    I'd try a coil on # 5 or 6 . Also take a good look at the 5 pin where the harness plugs into the coil. We have seen them melt together there. If you have a temp gun ,I like to check the coil temps ,it's a good way to see if anyone is dead . Are you looking at air and fuel psi at wot ? Have you looked into the jet pump stator veins and impeller ? Make sure the shift gate is not dropping down a little at wot . hf ...
    Feb 2005
    change the plugs next. they can some times act erroric[sp] under pressure. been there.
  1. Evinrude 225 HO Should I cut my losses
    By Stratos_Kid in forum Technical Discussion
    Last Post: 12-02-2015, 12:27 PM
  2. Looking for20 inch Sport master Lower Unit RH mercury Opti Max
    By ekaterina in forum General Boating Discussion
    Last Post: 09-24-2012, 10:00 AM
  3. Obama Losses a vote!
    By The Big Al in forum The Scream And Fly Lounge
    Last Post: 10-14-2008, 06:02 PM
  4. 225 Opti Sport XS Fuel consumption
    By stingray240cs in forum Low-Emission Outboard Engines
    Last Post: 04-30-2007, 10:21 AM
  5. Wins and Losses using an EGT?
    By Johan in forum Technical Discussion
    Last Post: 02-28-2002, 10:04 PM
