Page 2 of 2 FirstFirst 1 2
Results 16 to 22 of 22
    Dec 2001
    Most any thing can be fixed......is it worth fixing?... Drill hole tap and Good bolt. Don't know if the crank is too hard for that.
  2. #17
    Aug 2009
    mpls,mn
    Problem now is how much more damage will be done just to get the flywheel off?
  3. #18
    Ft. Lauderdale, Fl
    Quote Originally Posted by racervboat View Post
    Heat the hub of the flywheel and two pybars and a whack on the crank with a hammer should get it off.
  4. #19
    Aug 2009
    mpls,mn
    Yeah maybe so,but man he must have had some serious torque on that snap-on puller to that much damage and to not know he was doing it ?
  5. #20
    Nov 2009
    hardyville va
    Quote Originally Posted by Treeguy View Post
    someone didnt wait till i got there
    so anyone know where there is good crank to be bought
    Why was the flywheel being pulled? No stator under there. Dress it up enough to get the nut back on and let it eat. It's junk anyway.
  6. #21
    Aug 2009
    mpls,mn
    Im thinkin motor needs a rebuild? or a bad crank bearing ?
  7. #22
    MIAMI FLORIDA
    As chaz said see whats there once u get the wheel off.. doesn't merc use that big like .200 thick washer under the nut? may have enough threads to put a low profile aircraft 12 point nut on with a thinner washer orrr....wouldn't be that big of a deal for a good machinist to cut it off bore and thread it for a fine thread hard 12 point bolt, would be no different than the drive end of most 2 stroke jet ski and snowmobile engines with internal threads on the taper. But.... probably easier to find a used one since u have to pull it apart to fix it anyway. Dave
  1. Mercury 3 liter crankshaft
    By Phil Conant in forum Misc. Parts and Accessories
    Last Post: 09-19-2017, 01:01 PM
  2. Mercury 3 liter crankshaft
    Last Post: 09-19-2017, 12:56 PM
  3. Yamaha 3.1 liter crankshaft assembly
    By M.CHAPMAN in forum Misc. Parts and Accessories
    Last Post: 10-02-2014, 12:55 PM
  4. Will a 2.0 merc crankshaft work in a 2.4 liter?
    By 370VRanger in forum Technical Discussion
    Last Post: 12-03-2008, 08:45 AM
