Results 1 to 4 of 4
    Oct 2015
    Kentucky lake
    Help with port map options
    Help with port map options , needing help with picking port timing changes to move rpm range up and make has much power as possible. . I've got a 1985 merc XR2 2.0 I've learned it doesn't have finger ported pistons or block.. so far I've got chest work cut , and rod slots cleaned up. Going to D port pistons also. Click image for larger version.
    Dec 2001
    Take ya finger in the top of Exhaust port. Feel the sharp cut..... round rat tail till smooth.
    Dec 2001
    I am not talking about the top of port for timing but the sharp edge of the bend in the port.
    Oct 2015
    Kentucky lake
    Thank you Dave s I'm guessing that would help flow lil bit to round that sharp corner.. I'll need to be careful on the bore not to get out there
  1. OMC 56 Oval port motor port specs
    By phillnjack in forum Technical Discussion
    Last Post: 09-02-2017, 10:34 AM
  2. Mercury 115hp inline six port map/ power port dimensions
    By janihei in forum Technical Discussion
    Last Post: 03-06-2017, 11:31 AM
  3. Mercury 2.4 pistons, finger port style and early style with just the boost port.
    By Phil Conant in forum Misc. Parts and Accessories
    Last Post: 08-16-2014, 05:35 PM
  4. 225 Promax - to port or not to port?
    By 30Motion in forum Technical Discussion
    Last Post: 05-23-2006, 11:35 AM
