Results 1 to 15 of 21
Thread: side pin vs top pin
12-28-2017, 09:33 PM #1
side pin vs top pin
when did this come about and why .
12-29-2017, 01:39 PM #2
outasite thanked for this postDave Strong liked this post
12-29-2017, 04:00 PM #3
I know it happens but just don't get how the pin can get past the ring gap? but it sure does happen.
12-29-2017, 05:23 PM #4
12-29-2017, 05:26 PM #5
Thought it was the factory 2.4 Bridgeport that started to loose the pins first?
12-29-2017, 05:36 PM #6
I never heard of a problem till they switched to wiesco's. the top pin 280 wiescos came out in 03'-04'?
is gone
12-29-2017, 06:14 PM #7
reason is i have a set of side pin mahle's i bought from jay smith racing and being low hour and fine condition was thinking of using them without having top pin till next go around ring job.
12-29-2017, 07:30 PM #8
I wouldn't have a problem running the "real" Mahles, but not the pro marine junkers!
is gone
JPEROG liked this post
12-29-2017, 08:07 PM #9Screaming And Flying!
- Dec 2001
- 9,502
- 271
- 191
- 1976
1949 mercs were top pinned. Maybe 1954 they went side pin so the gaps didn't line up. No problem ever with merc rings turning till V6 big bore motors. Because the exhaust port is big and has no bridges. Every time the ring goes past that big hole it beats the locating ring. Bigger hp bigger hole. The shape also makes things happen differently. A nice shape will ease the ring back better. The pin on some pistons are fully covered by the ring....most 2.0/2.4s. Those are bigger pins than the ones on 2.5 motors that are half covered by ring. Most stock pistons will live till you bear/rev too much.Wiscos grow more and the pins fail. The males have trick wrist pin locks..... try to get them.
12-29-2017, 08:30 PM #10
Ain't buyin' it, never had a problem with the Austrian made Mahles, throw the wiesco's in and BOOM!
is gone
12-29-2017, 08:37 PM #11Supporting Member
- Apr 2003
- New Smyrna Beach, FL./LOTO
- 6,633
- 606
- 917
- 1698
- 7129
- 3 Post(s)
Detonation is the biggest culprit. Out of all the 2.4s and 2.5s that I have run, I had one pin rattle out. It made a mess but I shouldn't have been running old fuel and knew better.
12-29-2017, 08:45 PM #12
Thing was how does the pin get out past the ring gap? heat?
12-29-2017, 09:31 PM #13
Think it keeps wearing gene trichel from Oshkosh showed me many years ago how to properly stake pins in 86 200 so they don't move outward
12-29-2017, 09:33 PM #14
Think i,m going to lighten these and run them
12-30-2017, 08:15 AM #15Screaming And Flying!
- Dec 2001
- 9,502
- 271
- 191
- 1976
I think males are good.....don't know where ya going to lite em. 6000 rpm....100 per sexond.....things are happening fast. Turn up the speed....Ring flutter.
Converting Action 18' side x side to center steer?
By Upstaterpaul in forum Props, Setup, and RiggingReplies: 6Last Post: 09-08-2014, 05:15 PM -
Slight side to side movement at flywheel
By racer7x in forum Technical DiscussionReplies: 16Last Post: 10-15-2013, 03:15 PM -
Just blew apart a side skirt on exhaust side of ym 225 3.0 225 mariner
By duane1982 in forum Technical DiscussionReplies: 2Last Post: 07-13-2011, 01:28 PM -
Twin 2 litre Mercs side by side on a T4 Housing
By MagicFloat in forum Outboard and Racing HistoryReplies: 21Last Post: 01-08-2003, 07:48 PM
