Results 1 to 3 of 3
    Oct 2017
    Miami
    CLE Lower Unit Impeller Kit
    Good day fellas, i recently purchased a 2.5 200 Merc and i will be changing the impeller kit. I was looking to find out which kit to purchase because the water tube is bigger then the others I’ve used on the bobs. Any suggestions?
    May 2001
    Ga
    The gaskets and impeller are the same . The upper housing , line up tube and copper water tube are larger . I'd only replace the housing it it's warped from heat on severly groved from wear . Hf ...
    Oct 2017
    Miami
    So how would i attach the upper housing to the water tube? When i pulled it apart, there was a hose over the upper housing on the water pump and the water tube.
  1. Suction side on impeller on merc lower ?
    By Keaten in forum Technical Discussion
    Last Post: 08-27-2016, 04:52 PM
  2. mercury quicksilver lower unit vs tourqmaster lower unit
    By jshotts in forum General Boating Discussion
    Last Post: 01-26-2015, 01:23 PM
  3. Mercury Tech: 2.4, 2.5 liter fishing lower unit into a 3.0 torque master lower unit
    By cactusth in forum Technical Discussion
    Last Post: 08-12-2011, 09:51 PM
  4. Mercury Impeller Differences between Lower Units
    By dry3 in forum Technical Discussion
    Last Post: 03-24-2006, 04:06 PM
