Results 1 to 9 of 9
Thread: Startron
    Miami,Fl
    Startron
    Is this stuff any good? I have 3 month old non ethonol mixed gas and want to run the boat on New Years 140 crossflow an I safe to run it or do I need to dump. I actually have no place to dump appreciate any advice. thanks Rick
    uf you were here you could bump it in my boat tank, if its non ethanol then just use it..
    Sep 2016
    McHenry,Illinois
    I use it exclusively winterizing 500+ boats a year...I believe it even says on the bottle "rejuvenates" old fuel. If you put it in your fuel 3 mos ago I would go ahead and run it. If not you might want to use it and possibly put in some octane booster as someone posted in an earlier thread. I'm going to be in the same predicament in the spring with my 135 xflow. If anyone can recommend a good octane booster please post as I have never used it before.
    Hustler 15' Wildcat / Merc 80
    Hustler 13' Wildcat / Merc 80
    Hustler 13' Picklefork(Experimental) / Merc 80
    Hustler 16' Victor / Evinrude 85
    Hustler 15' Tunnel / Evinrude X115
    Hustler 17' Lark / Suzuki 140
    Hustler 16' Victor / Johnson 135 (current and restored)
  4. Thanks delawarerick thanked for this post
    Royal Purple boost with Royal Purple 2 stroke mix in min 91 fresh pump. Throw in Royal Purple Max Gear oil in the lower as well. I use 75 /90 but you can get it thicker, up to 140.
    Wait, what, 500+!!!
  6. Thanks delawarerick thanked for this post
    Sep 2002
    Atascadero,Calif
    Aces 2 stroke
    Gary
  8. Thanks delawarerick thanked for this post
    Likes mach351 liked this post
    Sep 2016
    McHenry,Illinois
    We store 350ish boats a year plus all the boats winterized that are not stored...in truth something less than 500 most years
    Wait, what, 500+!!!
    That's a lot of boats to get through
  11. Likes DanUmbarger liked this post
  12. #8
    FL / NY
    I use it all the time especially here where gas sits for some time. I actually run it in the motor then let it sit.
  13. Thanks delawarerick thanked for this post
  14. #9
    Miami,Fl
    Thanks for the advice I run around 150 compression that is the way the motor came. I have finished the storm repair and I am ready for the water was 80 yesterday. I did my fair share of winterizing but there was no ethanol when I was doing it. Would love to buy some aces but royal purple boost is available. Rick
  1. Startron any good?
    By delawarerick in forum Technical Discussion
    Last Post: 03-26-2010, 06:13 PM
  2. Startron fuel additive
    By CALVIN in forum Technical Discussion
    Last Post: 08-13-2007, 09:13 AM
