Results 1 to 14 of 14
    Nov 2003
    Need help with Johnson wiring
    I having trouble identifying and location where these three wires go. 2001 Johnson 225 HO. Any help would be greatly appreciated. Mike
    Two gray wires one male and one female connectors.... One orangish wire with black tracer female connector....
    ft pierce fl
    Grey is tach. Tan with or without tracer is Temp wire. Black is ground for something. I would think all three are connected near ignition pack on top of motor. The grey to grey on ign pack. Tan to sensor in head or top of block. Black could be temp sensor ground.
  3. Thanks skiboater thanked for this post
    Ft. Lauderdale, Fl
    The tan and black wires could be the oil tank level connections and the gray for a test tachometer.
  5. Thanks skiboater thanked for this post
    Likes davemvegas liked this post
    Nov 2003
    I'm not using the VRO. The tan and black wires make sense.... Thanks
    Ft. Lauderdale, Fl
    Quote Originally Posted by davemvegas View Post
    Tan can also be oil pump or oil tank alarm.
  8. Thanks skiboater thanked for this post
    May 2006
    Tan with the black stripe is the SystemCheck gauge LOW OIL wire from the oil tank plus its black ground connection.
  10. Thanks skiboater thanked for this post
  11. #7
    Sep 2002
    Atascadero,Calif
    Take a pair O wire pliers and just cut all the ones you don't know are...cut and be done with it. Easy Peazy!
    Merry Christmas to you Buddy... you too Mike.
    Gary
  12. Thanks skiboater thanked for this post
  13. #8
    Nov 2003
    Easy Peazy.... I like it.... Merry Christmas Gary..... Thanks everyone for the help.....
  14. #9
    Jul 2013
    Gary, do you still have that Allison that likes to get its occupants wet!
  15. Likes skiboater liked this post
  16. #10
    Sep 2002
    Atascadero,Calif
    I do.... sorta. The Allison(SackOCats)is still in AZ...AKA The Bat Cave(Dave Bush's Gayrage). Engine in pieces scattered throughout the compound. Hopefully I will be summoned along with skiboater(Mike Lambert) this winter/spring to slap it back together. I'm not holding my breath as it's been a couple of years...
    Help me as my feeble mind does not remember who you are Onetime. I apologize, butt as I have said before when I cannot remember...I've slept since then.
    Gary
  17. #11
    Jul 2013
    I know Bill. Was in it onetime when it got him wet.
  18. #12
    Sep 2002
    Atascadero,Calif
    I see... question is did you also get wet. When I got wet it was my fault. Butt when I got helped back in I was asked "How fast do you think you were going?" I punched the tattle tail on the GPS... 100.9 . It has been the fastest but wonder if I can call it my personal best.
    Gary
  19. #13
    Singapore/Melbourne
    did the DBR 450hp engine survive other then being wet?
  20. #14
    Sep 2002
    Atascadero,Calif
    Yep, good thing I always wear the Lifeline and have the kill switch clipped. When I surfaced, I was about 3' under, I had to turn 180 to see the boat a couple hundred feet away facing away. Just sitting there like it never happened. LOL
    Gary
  21. Likes powerabout liked this post
  1. OMC Tech: Johnson wiring questions
    By 0081 in forum Technical Discussion
    Last Post: 02-24-2014, 01:41 AM
  2. 1984 Johnson 235 hp wiring
    By Liberator225 in forum Technical Discussion
    Last Post: 07-26-2011, 03:57 PM
  3. OMC Tech: Johnson 9.9 wiring question
    By LaveyT in forum Technical Discussion
    Last Post: 06-02-2011, 07:20 AM
  4. OMC Tach Wiring - Johnson RS
    By RogerH in forum Technical Discussion
    Last Post: 01-16-2010, 04:15 PM
  5. 2000 200 johnson need wiring help please
    By shat70 in forum Technical Discussion
    Last Post: 04-17-2007, 10:20 AM
Simon Motorsports
