Results 1 to 5 of 5
Thread: 1997 mercury promax 225
12-22-2017, 04:59 PM #1New Member
- Dec 2017
- Australia
Hi there, i have a 97 mercury promax 225, the ECU has failed so i am converting to carbs, i have a set of WH15's to bolt on but need to know what would be the best 12volt fuel pump or the required fuel pressure i would need so i can retrofit a pump?
12-25-2017, 07:57 AM #2
Please do your self a favor and keep the efi. Buy a Brucato acu.
Nitrous is like a slut. u wanna hit it but you know there will be consequences.
12-25-2017, 09:36 AM #35000 RPM
- Sep 2011
- Deplorableville
- 740
- 1347
- 76
- 3211
- 1452
Send the ECU to Dennis Hoffman, he can repair it cheaper that the cost of the carb swap and the headaches that go along with carbs.
90 5.0 liked this post
12-25-2017, 01:06 PM #4
12-25-2017, 01:08 PM #5
But to answer the actual question, Holley red or a carter and a return style regulator.
4-5psi.
I’d find carbs off a 245 2.5, the pm is closer in porting to a 245 than the 200 the wh-15’s came on
1997 Mercury 225 Promax Issues After Dealer Install
By Lestat in forum Technical DiscussionReplies: 15Last Post: 09-02-2016, 12:14 PM -
1997 Mercury Promax 200
By 2scoops in forum Outboard EnginesReplies: 21Last Post: 04-25-2015, 11:32 PM -
Idle Speed question for 1997 Mercury 2.5 Promax
By HST Madman in forum Technical DiscussionReplies: 0Last Post: 09-12-2004, 05:08 PM
