Page 3 of 3 FirstFirst 1 2 3
Results 31 to 44 of 44
  1. #31
    Sep 2017
    Thanks Guys I will give it a go tomorrow without the lines connected to the big tank. And premix planning on pouring out the gas on the on board water fuel separator and priming back with fresh pre mix. Will the pre mix be a problem goin through this filter? I’m thinking it should be fine but just askin to be sure once again thanks to everyone and have a Merry Christmas
  2. #32
    Ft. Lauderdale, Fl
    filter is fine with premix
  3. #33
    Ft. Lauderdale, Fl
    Also, mark the reservoir at the oil level and let the motor run about 15 - 20 minutes and check the level again to see if the oil system is working.
  4. #34
    Nov 2004
    LEBANON OREGON
    simple answer.... drive it to someone qualified
  5. #35
    Sep 2017
    Ok Guys had a chance to start motor. Started right up. Was very happy. Bought this motor without seeing it run.Now that it starts have the Vst apart ton
    Of Crud still dont know how the pump is still itworking. Removing injectors for serviceClick image for larger version.
  6. Likes Capt.Insane-o liked this post
  7. #36
    Sep 2017
    Sep 2017
    Going to replace old pump and filter .new gasket and seals put it all back together .Click image for larger version.
  9. #38
    Put a new needle in the vst too
  10. #39
    Sep 2017
    Capt Insane-O thanks so much appreciate the heads up.Especially the Fuel pump! There local for me out here in CA so I’m able to drive and pick it up. Vst tank cleaned up well have most of the crud gone. Which has me concerned about the fitting for the oil mixture line. Exactly how does it work? I mean when gas is inside of the vst no gas leaks out. So I’m thinking it’s clogged from the crud,although I don’t see any crud in the fitting. Some light shined on this matter would be great
  11. #40
    It has a spring loaded check valve in it to keep the oil from filling the vst. Judging by the build up I'd carefully clean or replace it.
  12. Thanks endurance thanked for this post
  13. #41
    Sep 2017
    Thanks I just been letting it soak. Thinking more on the lines of replacing
  14. #42
    Some people ask why do you drain the VST for storage? Your pic is a perfect example.
  15. #43
    Ft. Lauderdale, Fl
    Also drain the oil tanks, probably full of sludge too......
  16. Thanks endurance thanked for this post
  17. #44
    For some reason all of my old 3.0 EFI'S have had the hose from the top bearing to the bottom crank case fitting go bad first. Way before the others. May be heat related? Or, because it's the hardest one to get to? Ha ha
  1. GT-150 in the water after sitting over 20 years
    By gregpro50 in forum General Boating Discussion
    Last Post: 06-21-2013, 10:00 AM
  2. mercury 250 efi starting after sitting
    By speedthriller in forum Technical Discussion
    Last Post: 08-14-2011, 06:56 PM
  3. Evinrude sitting for years
    By tracktech in forum Technical Discussion
    Last Post: 08-25-2008, 06:06 PM
  4. Starting a motor that's been sitting for years
    By gbourdon in forum Technical Discussion
    Last Post: 08-20-2008, 04:25 PM
  5. 2.5 EFI been sitting 2 years...
    By yanny_haulinbass in forum Technical Discussion
    Last Post: 04-18-2006, 09:19 AM
