Results 1 to 12 of 12
    May 2017
    Ca
    225 promax erratic water pressure gauge?
    Noticed last trip of the summer out my water pressure gauge was bouncing around a lot. Between 5&14 psi while cruising on plane. I took a video but canít figure out how to upload. Didnít seem to be over heating or anything. Boat ran great. Iím suspecting poppet valve? Sport master mid. Water pumps less than a year old. Needle on gauge bounces back and forth pretty violently. Good sTeady 3-5 psi at idle. Any ideas?
    May 2017
    Ca
    https://youtu.be/VnvAXi_V5H0
    You can see the gauge bouncing around for a few seconds in this video
    May 2017
    Ca
    Curious if this is why I also have a kind of blubbery loaded up take off after idling for extended periods of time. Maybe the poppet is stuck and filling the mid up with water
    Mar 2010
    houston, tx
    Crap in the water ports and poppet dump will do that.
    Running in crappy water a lot I have to mess with that often. I’ve always got crud in my water passages and that’s rhe first sign ofnit.
    May 2017
    Ca
    Gotcha. I boat in pretty shallow water good chance there’s some sand or what not in places it shouldn’t be
    May 2017
    Ca
    Quote Originally Posted by 90 5.0 View Post
    Your saying that will cause the loaded up thing at idle or the bouncing water pressure gauge? Or both?
    Mar 2010
    houston, tx
    Quote Originally Posted by Bunger View Post
    Both depending on where and how bad the restrictions are.
    Ive had pebbles all in my passages and sand and crud and seen 15-20 at idle until it blows some by
    FL / NY
    Simple and quick attempt to clean system, back flush with good pressure. If you have stats open and check them also.
  9. Likes XstreamVking liked this post
  10. #9
    May 2017
    Ca
    Talked to the guys that rebuilt this motor for the p/o and he said that it’s bormal for thto gauge to jump around at a certain rpm. The poppet doesn’t know what to do so it opens and closes. Kind of makes sense?
  11. #10
    Mar 2010
    houston, tx
    Maybe, but I’ve only noticed it when I’ve had crud in the passages. It’s always steady that I’ve noticed normally, especially if the therms are open and it’s warmed up.
  12. #11
    Not with the gauge flickering that fast, mine have always been pretty steady and it drops about 2 psi as the t stats cycle. When the poppet opens it drops from 15-18 to 10 and then the pressure builds steady to 30 psi as speed increases.
  13. Likes tux974 liked this post
  14. #12
    FL / NY
    I agree with Capt. It should not bounce but move gradually in either direction.
  1. Mercury Tech: Promax water pressure gauge hookup
    By CHICKENHAWK in forum Technical Discussion
    Last Post: 07-10-2017, 08:48 PM
  2. Replies: 2
    Last Post: 09-04-2014, 05:33 PM
  3. Mercury Tech: erratic water pressure
    By Basinbeast4.3 in forum Technical Discussion
    Last Post: 02-10-2014, 11:47 AM
  4. water pressure erratic....
    By cocacola in forum Technical Discussion
    Last Post: 05-24-2010, 03:53 PM
Mazco
