Page 3 of 6 FirstFirst 1 2 3 4 5 6 LastLast
Results 31 to 45 of 88
  1. #31
    Quote Originally Posted by dwilfong View Post
    This is my take on fresh air.
    The stock cover goes over the front hole in the cowl when running.
    Sounds killer with the resignation in the box.
    Think about the ex chest and how it works.
    Now look up resonators and do some reading.
    http://www.me.umn.edu/~hork0004/2006-01-3654.pdf
    I hate reading SAE papers my self.......................LOL
    This is what I'm thinkin of ..... has to be better than suckin in hot air. AirRaid and K&N say their cold air auto systems make more hp. Would need to see dyno proof BUT it makes since considering turbo intercoolers help make big hp.
    Gary
  2. #32
    Quote Originally Posted by Forkin' Crazy View Post
    Here is one I modified. I kept the slots high and being cut in the angle of the cowl does create some what of a ram effect. I glassed up the rear handle because some cowls will suck in water from the spray, and I wanted it more air tight.
    Attachment 394839
    Paul being a Finish carpenter originally(I'm finished all right) I'm curious as to what tool(s) did ya use to cut the slots. I've been usin a Fein Multi Tool to hack at mine....I did an old 25hp yrs ago (louvers) with it but I'm always lookin for better and easyer methods.
    Thanks Gary
  3. #33
    Aug 2009
    mpls,mn
    Gary or a rotozip with fine blade?
  4. Thanks olboatman thanked for this post
    Likes olboatman liked this post
  5. #34
    NE Louisiana
    Ram air is fine, unless you are directing it down the carb throats.
  6. #35
    Jun 2017
    fife scotland
    So if you force air into the cowling but not down the carbs thuis is a good thing ?
    I love my Bikini
  7. #36
    Yes
    If the air is forced into the cowl it should not be plumbed tight to the carbs(injection) so to force open the reeds. Allowing the intake to only draw fresh air from outside the cowl is an upgrade from stock.
    Gary
  8. #37
    Jun 2017
    fife scotland
    So if i add an intake like this Click image for larger version.
    And open up the handle at the back of the cowling like so Click image for larger version.
    This will allow fresh cold air but at the same time blow the hot air out
    Any thoughts on this ?
    the other options is to have the scoop vertical on the front facing down and have 2 slats cut just at the back of the air silencer
    Thoughts please guys
    I love my Bikini
  9. #38
    What you show in the two pics is where I am goin with my 140 OMC. I cut a hole in the cowl in front of the carbs, added a plate about an inch off the hole to break the air flow and keep out water. Also I opened up the hole under the rear handle that I tipped up so to act as a venturi to suck air out the rear. When I get the cowl back from the vinyl shop I'll post some pics with the rest of the project.
    Gary
  10. Likes spybot liked this post
  11. #39
    Aug 2009
    mpls,mn
    spybot gary is not using a front plastic cover in front of carbs just like my motor.
  12. #40
    Jun 2017
    fife scotland
    Quote Originally Posted by racervboat View Post
    So the black plastic cover that is screwed to the aluminium plate is taken off ?
    That would leave the 4 barrels of the carbs left open ???Click image for larger version.
    The plastic part is circled red. This part will be removed ?
    Andy
    I love my Bikini
  13. #41
    Jun 2017
    fife scotland
    Gary
    Look forward to see it Gary
    Andy
    I love my Bikini
  14. #42
    Aug 2009
    mpls,mn
    Yes and the alum casting is cut down around the carbs except the two mounts that hold throttle and shift cables.
  15. Thanks spybot thanked for this post
  16. #43
    Jun 2017
    fife scotland
    Go it. Is there any gauze or mesh over the throats or the alu thats left ?
    Is it just plain ?
    Andy
    I love my Bikini
  17. #44
    Aug 2009
    mpls,mn
    just plain,but were not running the boat down a dirt road LOL
  18. Likes FORBESAUTO liked this post
  19. #45
    Jun 2017
    fife scotland
    Thats true but over here at every loch we have a small fly called a midge pronounced mid-gee
    https://en.wikipedia.org/wiki/Highland_midge
    They are a total p.i.t.a. They attack in swarms. Not nice especially if you drive through them
    They bite like hell and love the taste of blood.
    I may think about some sort of gauze.
    Andy
    I love my Bikini
  1. Looking for someone to modify my 6hp powerhead to max performance
    By jayjays in forum General Boating Discussion
    Last Post: 12-27-2006, 12:38 PM
