Results 16 to 30 of 97
Thread: Ingredients to make killer 2.0
12-17-2017, 10:15 AM #168000 RPM
- Feb 2007
- lily lake WI
- 3,206
- 57
- 1561
- 342
It was my plan to run a 2.0 champ mod u motor on a lite Allison drag boat just for fun but all of a sudden these motors went from $3500-$5500 to $7000-$8500 for that price it will just be a dream i will stick with my drsgs and my 2006 280/drag dam shame because the old 2.0 liters where good little motors
Keaten thanked for this post
12-17-2017, 10:15 AM #17
Yes sir .. and if the "overrun" units that were not blems , you had to pay for them as well . Which still hold's true to this day .
Chaz = thinkin , if someone has never ordered customs .. "WELP"... never mind I have never stuffed thousands worth of Benjamin's in the mailbox and lifted the outgoing red flag .. so what do I know about being assigned a part number of my own ..
12-17-2017, 11:47 AM #18
I really like these little motors due to longevity reasons. Next year I'm going to have to bite the wiener and make an order me thinks. Sucks but at least the bores stay round.
Michael J Giesler liked this post
12-17-2017, 11:56 AM #19Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
12-17-2017, 12:19 PM #205000 RPM
- Oct 2015
- Kentucky lake
- 480
- 31
- 15
- 60
Ok in a perfect world were nothing ever goes wrong or breaks ,if a guy mods a merc 2.0 fishn block with 150 psi heads and 200 psi heads to play with, perfect leak down %s , ground out chest to run 10k ,changed port timing need help in this area for shure !! good pistions top pinned with merc rings, hone holes to match, d or square mod done on pistions with adding a additional hole or holes to pistions, big rods for the rpm i guess? 5 or 7 front with a lot off front much as possible, port reed cages little less than crazy add CCMS reeds 1" intake spacer, wh15 or 20 carbs will start out fat on jetting say 46 idle and 85 mains.. wat would I have then... if done perfect say.. 175 hp lol hope not.. more like 250 at 7-10k ?
12-17-2017, 12:34 PM #21
The factory 2.0 fish blocks have a big heavy cast iron jug cast in the block, it's not a sleeve like a 2.5. Which makes them more difficult to port. Order an old oval port f1 sleeve from LA sleeve and copy that.
12-17-2017, 04:30 PM #22Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
I don't know either teach! Get to the principal's office he said.
12-17-2017, 04:44 PM #23
Late model pistons. They can be used in older models with new rods.
12-17-2017, 06:49 PM #24
I have no doubt they know what their doing .
You might have even bought a dozen pistons and a couple spares ... once in your life.
But just as you misquote non applicable text and pictures of a Sea-Do , as having some relevancy to Mercury outboards , I have no doubt you misquoted "the man on the phone" at Wiseco . Which normally should be no big deal . But since it's me ... you would rather stand behind something you have never done nor went thru the beginning stages of having a custom piston built than just say , that you don't know .
Pretty sad , that you would let a guy order sleeves , have a block machined , and then find out that if he in fact needed a custom . It would actually have to go thru engineering and that he would have to sign off on the prints .
And of course , you would need to have an account with banking information on file before they will even consider a custom project . ( they want to get paid for their time )
Like I said there is a minimum order and customs cost more than standard kits . And if you call back the next week ... even for the same part number , you go back to the minimum order . There is no price break unless you order 48 unit all in one shot . Which means it's not cumulative . I do hope that has cleared up some of your confusion on ordering custom pistons .
Cash no chequeinzee ehh ? That I can't say . I'm an American citizen with a clean banking record . A line of credit and references .... and you ???
12-17-2017, 06:56 PM #25Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
You must be thinking of yourself, you can't hold a candle to me. Friend
And what are you going on about, letting a guy order sleeves???
Why get all spun about what someone said to me about a small custom order regarding easy mods to an existing product line?
Krazymaan liked this post
12-17-2017, 08:17 PM #265000 RPM
- Oct 2015
- Kentucky lake
- 480
- 31
- 15
- 60
Dwilfong can forward me a example of a port map print to learn from
12-19-2017, 12:45 AM #27
12-19-2017, 02:19 AM #28
xr2 is steel sleeved. Just a righty sst120/s2000 motor. Still piston ported.
RBT liked this post
12-19-2017, 08:09 AM #29Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
I see what you're saying having the thick sleeves to do your port work but 2.5 vs 2.0 displacement?
12-19-2017, 09:44 AM #30Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
You know a rebuttal will be forthcoming from somewhere.
Wtb non Rachel ingredients 1:87 reverse gear
By pappa pete in forum Lower UnitsReplies: 1Last Post: 03-24-2017, 01:09 PM -
killer killer photo.........surfaced speedmaster....trick
By PARKER RABE in forum General Boating DiscussionReplies: 15Last Post: 02-05-2011, 08:14 AM -
Sorry dog killer..................
By skydog in forum The Scream And Fly LoungeReplies: 8Last Post: 11-30-2010, 01:22 PM -
Time to make your keyboard make a differance!
By The Big Al in forum The Scream And Fly LoungeReplies: 1Last Post: 04-08-2006, 02:12 PM
