Results 1 to 11 of 11
12-15-2017, 08:52 AM #15000 RPM
- Jun 2011
- Australia
- 128
300xs HD trim hose fitting thread damaged
Hi all,
I recently purchased a 2007 300xs Midsection with the heavy duty bracket. Unfortunately, I have found that one of the trim hoses has a damaged thread in the internally threaded flare nut on the upper fitting near tilt pin (closest hose in the picture below).
Before changing out the hose, I would like to attempt to clean up the tread with a thread tap. Does anyone know the size/pitch of this tread?
Thanks againLast edited by Primal 98; 12-15-2017 at 09:15 AM.
12-15-2017, 09:18 AM #2
Don't think its deep enough to get a tap in it ? dremel tool might do it.
12-15-2017, 09:26 AM #35000 RPM
- Jun 2011
- Australia
- 128
Thanks, yes, I am worried about that, but the damage is on the first few threads, and I'm hoping a blind tap may just clean it up.
12-15-2017, 09:54 AM #4
Can't you just replace the nut?
12-15-2017, 09:59 AM #5
If you have a spare male fitting (regular steel, hydraulic fitting) use your dremel and cut some slices in the threads (like a tap)
Then with oil carefully cut the internal threads (take your time) :-)
Or ... change the nut, remember double flare.Wriggleys gum makes me think of boating, "Double your engines, Double your fun"
12-15-2017, 07:04 PM #65000 RPM
- Jun 2011
- Australia
- 128
Thanks Nice Pair, I don't have a spare fitting, but I will give that a go if I can find the right fitting (I don't have a spare) any idea on the thread pitch/size as I should be able to pick up cheap locally.
Failing that I will see if I can get a local hose shop to cut off/replace with the hose still fitted, and take it from there.
Thanks again
12-15-2017, 07:33 PM #7
12-15-2017, 08:09 PM #8
Can't you just replace the whole line?
12-15-2017, 08:39 PM #95000 RPM
- Jan 2013
- GA
- 212
- 35
- 10
- 43
- 32
If I had to guess, maybe a #6 JIC
12-16-2017, 09:33 AM #10
How is the hose from the pump to that fitting? might have to buy two hoses?
12-27-2017, 03:36 AM #115000 RPM
- Jun 2011
- Australia
- 128
Thanks to all for your input. I managed to clean up the thread with the dremel, lubricate it and slowly work it on. I have removed and installed it a couple of times now and it looks good to go.
Thanks again
NICE PAIR liked this post
?? fitting on side of 2.5 260 horn w/hose to regulator
By liberatorx2 in forum Technical DiscussionReplies: 6Last Post: 01-27-2014, 02:01 PM -
Hose fitting for Mazco cone?
By Riverman in forum Technical DiscussionReplies: 8Last Post: 04-26-2011, 01:57 PM -
L/U Nosecone Hose - Fitting Corrosion
By Matt Gent in forum Technical DiscussionReplies: 6Last Post: 02-14-2008, 11:43 AM -
Cowl fitting for rigging hose on '89 V6 Merc
By jallen355 in forum Props, Setup, and RiggingReplies: 12Last Post: 11-18-2007, 05:26 PM
