Results 1 to 14 of 14
12-14-2017, 06:38 PM #15000 RPM
- Sep 2017
- ontario
- 717
- 68
- 43
- 73
- 171
Old racing formula 1 or 2 bridgeport
I have recently been thinking of replacing a 1984 200 merc with a bridgeport and while I was looking around I found a 2.4 bridgeport from an old formula race program . So it's a carbed and complete power head . So I'm told they have shaved heads and larger carbs and jetted and heard they run the opposite direction to usual for the #6 gearcases . So it means changing carbs to stock , flywheel and stator and stock heads, and I'm not sure but does starter also need changed up . I am not that knowledgable about outboards first of all but the powerhead can be had and just asking if heads and carbs with a flywheel and stator change can these items be bought relatively easily, or is flywheel specific to bridgeport and expensive .
The reason I ask I suspected the block ,rods and pistons - basic short block to be the expensive items and if the carbs , flywheel and such is rather generic I think I would move forward on this . Your education on the matter please . They do have some 12 inch midst and #6 gearcases available as well but that means running their props as well . I'm interested in the performance of the Bridgeport but not knowledgable enough yet to jump in .
12-14-2017, 06:45 PM #2Screaming And Flying!
- Dec 2001
- 9,502
- 271
- 191
- 1976
bEST OFF USING A 2.5 PH..... SELLING THE RACE STUFFF......SORRY CAPS STUCK....
12-14-2017, 07:58 PM #3
How much on the 12" mid ?
Cheaters never Win !!!
12-14-2017, 08:10 PM #45000 RPM
- Sep 2017
- ontario
- 717
- 68
- 43
- 73
- 171
I best ask him again because I was focused on the powerheads but what are they worth sir and can you help with stock bridgeport heads flywheel and carbs , and I will when talking ask for you on a mid but he is reasonable sir
12-14-2017, 09:02 PM #5
Sounds like an sst140 motor
Mark75H, Michael J Giesler liked this post
12-14-2017, 09:15 PM #65000 RPM
- Sep 2017
- ontario
- 717
- 68
- 43
- 73
- 171
I believe heard that reference, so can you expand that answer sir so as to better understand the class reference as far as the motor goes sir , I believe block and internals where spec and then carbs larger , heads shaved just as class rules allow . So a very suitable short block as far as reciprocating assembly just a tad high on compression .
12-14-2017, 10:45 PM #7
http://www.screamandfly.com/attachment.php?attachmentid=363987&d=1483582873
Easily converted to right hand with your starter, flywheel and throttle linkage.
12-14-2017, 11:02 PM #85000 RPM
- Sep 2017
- ontario
- 717
- 68
- 43
- 73
- 171
Thanks for the response so these were bridgeports or , I believe the motors I'm looking into are BP . Just trying to get informed before going forward .
12-14-2017, 11:19 PM #9
Yeah, I have the apba spec sheet somwhere. I believe they were ported a bit hotter than a standard BP but not a whole bunch.
12-15-2017, 07:56 AM #105000 RPM
- Sep 2017
- ontario
- 717
- 68
- 43
- 73
- 171
I will be getting a far more in depth discussion on these with him and I will understand the motor better now that I have been educated a bit here thanks . I can only suspect port matching is all that is allowed but don't know the rules . He mentioned carbs being larger possibly for the rpm that these sit at for the 20 minutes or so of race time . Is a stock carb rack easily had and heads . I believe he said fuel mix ,compression and carbs are all they are allowed and pinning of ring pins and improving reliability for duration with reciprocating assemblies with balancing and deburring . Not sure yet but he mentioned a shops name that they all came through for the series.
12-15-2017, 09:29 AM #11Screaming And Flying!
- Sep 2001
- shreveport,la
- 5,706
- 118
- 85
- 773
I'd leave the carbs on it if it's already setup. As said above, you just need a flywheel, starter and throttle/timing linkage to change rotation
Erik Kiser
12-15-2017, 03:26 PM #12
Definitely keep the left handed carbs.
mach351 liked this post
12-15-2017, 08:28 PM #13Screaming And Flying!
- Dec 2001
- 9,502
- 271
- 191
- 1976
Old race stuff not to be used on timm walkers fissing boat......just my iom....
12-15-2017, 09:36 PM #145000 RPM
- Sep 2017
- ontario
- 717
- 68
- 43
- 73
- 171
There are four of these powerheads from the program coming available and some 12 inch mids- double hydrolic and some #6 drives so if I your interested let me know and i will help . The power heads are 2500 each . All I have been told is they were good . So I can't tell you leak down or compression but was told they are from a race program and there are some cowls and skirts available as well . It seems like a great opportunity for the membership and preserving a bit of history .
2.4 bridgeport or formula cowl
By Cal 47 in forum Parts WantedReplies: 0Last Post: 04-05-2015, 08:03 PM -
Where's the Formula 1 racing
By mmmirage in forum The Scream And Fly LoungeReplies: 7Last Post: 06-28-2012, 03:10 PM -
Mariner Bridgeport/Formula cowl?
By JustMercMe in forum General Boating DiscussionReplies: 6Last Post: 09-21-2010, 07:02 PM
