Results 1 to 13 of 13
12-13-2017, 07:23 PM #15000 RPM
- Sep 2017
- Saugatuck, Michigan
- 318
OMC v6 power steering, bleeding ?
Anyone have experience with OMC / Johnson v6 or v8 power steering.
I have twin 1989 v6 225's, the system is pretty loose (sloppy). Is there any way to bleed the system ?
The system is original and might just be worn out....i don't want failure at 75mph.
Thanks
12-13-2017, 07:38 PM #2Scream And Fly VIP
- May 2001
- Hickory NC
- 5,583
- 18
- 250
- 204
- 464
- 4 Post(s)
First thing I would do is check pump psi.
12-13-2017, 09:03 PM #35000 RPM
- Sep 2017
- 318
Not to familiar with a system like this...
How would you check the psi ?
12-13-2017, 10:19 PM #45000 RPM
- Sep 2017
- 318
Thanks... I will try to find procedures on doing that
12-13-2017, 10:25 PM #55000 RPM
- Sep 2017
- 318
Also...been working with Sea Star on a replacement hyd system. The pkg would be;
A Pro tournament cylinder, a Pro supercharged helm, 1500psi lines and hardware kit.
Your thoughts on this package
12-14-2017, 12:05 AM #6Screaming And Flying!
- Jun 2007
- Singapore/Melbourne/Italy
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
use the screw in trim pressure gauge 984827, 850-1000psi at 1000rpm says the engine manual
There is a shimming procedure on the control valve
I'd be interested to try a full power system like Latham do for sterndrives whilst you have the pump side already doneLast edited by powerabout; 12-14-2017 at 01:03 AM.
12-14-2017, 08:00 AM #75000 RPM
- Sep 2017
- 318
Thanks for the procedure info.
I did contact Evan at Latham on a new system...unfortunately he has nothing that will work for my omc set up
Bart
12-14-2017, 08:17 AM #8Screaming And Flying!
- Jun 2007
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
12-14-2017, 09:10 AM #95000 RPM
- Sep 2017
- 318
The issue is the system is old works hard and is sloppy... Just wanted to see if I could tighten things up for the meantime. I plan on replacing all the bolts in the linkage and the ram I'm sure that will help some. I really want to go with a new front mount system still researching my options.
12-14-2017, 07:54 PM #10Screaming And Flying!
- Jun 2007
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
Do you have an engine manual, it shows how to re shim the valve
12-15-2017, 01:49 AM #115000 RPM
- Sep 2017
- 318
Actually I do...just purchased an original shop manual off ebay. Has greasy finger prints and all....i will spend sometime this weekend going through it. Thanks for the info
I appreciate all the help.
Bart
12-18-2017, 08:48 PM #126000 RPM
- Calgary, Alberta
- 1,123
- 21
- 58
- 341
- 174
12-18-2017, 08:57 PM #135000 RPM
- Sep 2017
- 318
I did disassemble mine...going to put new seals, etc.
According to manual.. sys is self bleeding
steering bleeding question
By hawk232 in forum Technical DiscussionReplies: 3Last Post: 02-26-2010, 08:06 PM -
Bleeding my steering
By KarzyKenny79 in forum Props, Setup, and RiggingReplies: 6Last Post: 06-04-2009, 11:21 PM -
Bleeding steering system
By vnemous in forum Technical DiscussionReplies: 14Last Post: 10-20-2008, 07:16 AM -
bleeding Seastar steering
By dma251 in forum Technical DiscussionReplies: 1Last Post: 08-31-2005, 12:54 AM -
bleeding hydrulic steering
By bigmotor in forum Technical DiscussionReplies: 0Last Post: 06-15-2005, 10:09 PM
