Results 1 to 11 of 11
12-13-2017, 07:09 PM #1
1979 Evinrude 235 Small Bore Crossflow
Hello. I am selling my 1979 235 Evinrude Crossflow. The motor has 6 new pistons with coated skirts, new piston pins, new rings and bearings, good set of rods, gasket set and CCMS reeds. Has some port work. Bubble Back Exhaust, Intake Stuffers, Big Bore Carbs, Gold Lightweight Flywheel, Unlimited Power Packs, Lightweight Cowl and Pan. Dry Stacked Midsection, 1.87 Lower Unit with Low Water Pickup and Pinned Carrier. Motor has less than 20 hours. 115 lbs. on all 6 cylinders. I had just switched over to Evinrude XD-100 synthetic oil. Ran with 93 octane non ethanol from day one. Asking $4000.00 or best reasonable offer. Pickup only. Located in Jefferson Parish, La. not far from New Orleans. Call or text 504-975-9494. My name is Jeff. Thanks for looking.
12-14-2017, 07:21 PM #2
Details about the motor not listed by Jeff:
-Custom MODVP cowl and pan....not just lightweight lol. (pan was glassed onto the adapter plate for added strength)
-Custom modified midsection...20"
-Complete brand new electronics
-Solid mounts
-Modified tuner
-New rod bolts
-Modified intake manifold and reed cages on top of the CCMS
-Modified exhaust deflectors and manifold
-All 6 rod/piston assemblies balanced to +/- 1 gram
-Finger ports
-Port work is fairly extensive....not in the terms of port height so much but opened past the 9 Pages specs
-The best part is the motor has "pins" around all of the cylinders to aide in keeping the cylinders round at high rpm's
-All machining done by Jim Ruck
I'm sure I forgot a couple things but this motor is still set up VERY conservative on fuel and timing....if the buyer is capable in tuning this motor, there is a lot of power on the table.
Jeff is as honest as they come too!I have a boat or two.... that I never get to drive
seychellesboy liked this post
01-15-2018, 12:22 PM #3
Bump
01-17-2018, 05:07 PM #4
How did you end up with such low compression for a '79 235?
Certified Experimental Engineer.
01-17-2018, 06:08 PM #5
01-17-2018, 11:26 PM #6
Wish i had the money i would buy it
boatman
02-12-2018, 07:51 PM #7Member
- Feb 2018
- Crosby/Huffman Texas
- 45
Still available?
02-13-2018, 07:37 PM #8
Yes it is still available.
03-01-2018, 02:16 PM #9
Bump
03-02-2018, 10:17 AM #10Member
- Feb 2018
- 45
PM sent
03-25-2018, 11:28 AM #11
SOLD! Thanks Scream and Fly!
OMC Tech: 1979 235 small bore evinrude
By tedd930 in forum Technical DiscussionReplies: 15Last Post: 03-26-2011, 11:52 PM
