Results 1 to 10 of 10
    Aug 2004
    TARPON SPRINGS FLORIDA
    Prop selection questions
    I have a 1994 21' seacraft copy weight is 1,500lbs with a 2002 evinrude DI 250. So far I have run 4 props all on the revlimiter. The only one that wasn't on the limiter was a 30p raker. The boat ran 4200rpms trimmed out and WOT. I like the way the raker runs so I was thinking of getting a 22 raker and having it built or getting a 24p raker or a 21p rev4. I think the 24 raker would be right in the middle of my 5500-6000 power range. If y'all come up with a different idea please help me out. Thanks
    Oct 2017
    Hugo, MN
    What pitch were the props you were running against the limiter?
    Also, I’m pretty sure running your motor WOT at 4200 is pretty hard on the motor. That 30 is way too much prop. On the other hand I fear going all the way down to 22 is going to be too little and back against the limiter.
    I’m no expert though.
    Aug 2004
    I started with the one that was on the motor. 16p SST, then a 18p Rebel, then a 19p trophy plus, then a 21p trophy plus in bad shape. All where on the limiter.
    englewood florida
    I have a 24 Raker I want to sell.
    18 Action 225 Promax
    Aug 2004
    I have an eye on your 24 if that is the proper direction for me
    englewood florida
    Quote Originally Posted by jimmyz32 View Post
    You are pretty close to me, you can try it out.
    lindsay on. canada
    RK has made you a good offer , you want that motor at 6000 wide open or a little more 6200/6300 . when the heat of the summer comes back you want it to be in the operating range near the upper limit . That motor does not like to lug ........
    Aug 2004
    Text me picks of the prop. 8134777109
    Aug 2004
    Thanks re for the prop. Frank Jackson you said these motors like to run at the 6k limiter?
    lindsay on. canada
    Over is better than lugging
  1. Some questions about material selection
    By Slimm in forum Fiberglass and Composites Discussion
    Last Post: 09-22-2015, 12:39 PM
  2. prop selection for a voo-doo with 60 omc? help please
    By voodoorye in forum Technical Discussion
    Last Post: 02-06-2008, 11:41 PM
  3. Prop selection questions...
    By Steve2ManyBoats in forum Technical Discussion
    Last Post: 08-16-2007, 10:57 AM
  4. prop selection???
    By talon in forum Props, Setup, and Rigging
    Last Post: 06-25-2004, 06:29 PM
  5. Prop selection for a T/H
    By Xallison in forum Technical Discussion
    Last Post: 12-09-2003, 12:32 PM
