Results 1 to 8 of 8
Thread: Bobs nose cone or not?
12-12-2017, 01:50 AM #1Member
- Apr 2017
- Orange County
- 58
I have a 21’ daytona, just bought a 300 promax for it. The promax came with a stock fleetmaster lower unit. I heard the bobs nose cone runs fast and is 5X cheaper. How well does bobs cone hold up against high speeds and occasionally rough water? Or just save up for a sporty ? Input appreciated.
12-13-2017, 08:08 PM #27000 RPM
- Feb 2005
- seattle
- 2,654
- 17
- 33
its not the nose cone you want,but the low water pu. i have both the bobs and sm and preferr the sport master for the nose lift and built in keel skeg.
12-14-2017, 02:24 PM #3Member
- Apr 2017
- Orange County
- 58
12-14-2017, 02:42 PM #4Screaming And Flying!
- 14,753
- 381
- 1305
- 5602
- 11033
The bob's cone properly installed will hold up to anything. For the 3 liters they have a dual hose setup for more water. They also sell a torque tab for the skeg to help with the paddlewheel effect of the prop when the motor is raised up. It is a toss up as to which is better. The bobs may be faster by a few and does cost less. The sporty has a big prop shaft, and is made for surfacing which your fleetmaster is not. Both have their advantages, most would put the money toward a sport master for it's superior design. I run a bobs on my stream, but it is flat water only and just occasionally run surfaced for any period of time. No problems so far. But when you surface any lower the maintenance goes way up. Waterpumps, gear oil, bearing carriers and seals need more frequent replacement.
litespeed, One Oldman liked this post
12-15-2017, 07:11 PM #5Member
- Apr 2017
- Orange County
- 58
Thank you for the input
12-19-2017, 11:33 AM #6
I would be curious to see how high i could run the fleetmaster with stock p/u and at what speed.
if the hull will run the number you want and happy with that ......idk if i spend the money for the few mph and increase maintenance mentioned above?
i know the rule of thumb is every mph after 85 cost big bucks before and after mods.
21 daytona is a bigger boat and may not need/want the ultra high propshaft location to run the number you want.
if i could try one first and get solid results worth what im willing to spend, fat shaft sporty all the way.
what is a fleetmaster worth on the used market? sell it to offset cost, may be close and there you go.
XstreamVking liked this post
12-19-2017, 02:57 PM #7Screaming And Flying!
- 14,753
- 381
- 1305
- 5602
- 11033
I have installed lwp lowers on boats that actually slowed them down. I would say about 1/2 the boats with lwp lowers don't need them.
KIRCHNER liked this post
02-08-2018, 12:19 PM #86000 RPM
- Feb 2011
- HUDSON, FLORIDA
- 1,528
- 433
- 64
- 435
- 452
i agradee i ran lots of mercs stock lower 4'' above normal never had cooling issues stock side intakes back in the day 15'' mercs on 20'' transom with big elephant ear 2 blade. i dont think bobs was even available then?
New in the box Bobs Nose Cone
By DrCatcher in forum Misc. Parts and AccessoriesReplies: 0Last Post: 12-20-2016, 02:01 PM -
WTB Bobs nose cone
By outasite in forum Parts WantedReplies: 0Last Post: 01-04-2016, 08:19 PM -
Bobs nose cone
By Hydropromax in forum Technical DiscussionReplies: 12Last Post: 05-20-2008, 12:49 AM
