Results 1 to 10 of 10
12-09-2017, 07:02 PM #1
GPS receiver/puck location on STV
Hey guys, Just bought a new gaffrig carbon fibre monster GPS Speedo, it's going to be mounted on my euro. I've seen a lot of people mount the receiver on the dash... Can it go anywhere else? There's no info in the install instructions on mounting location... curious if people have mounted them elsewhere with still maintaining an accurate reading, thanks!
15.5 cobra 175 hp merc - sold
18 tahiti tiger O/B 200 hp merc - sold
19 STV euro - 2.5 merc DRAG
Seebold F1 tunnel - 2.0 F1/champ
12-09-2017, 07:21 PM #2
Mine is glued under my deck and works fine. Use some tape and put it under there and check out what kinda signal you get. Beats having it on top of deck.JMO
12-09-2017, 09:10 PM #3
I have mounted dozens under the dash or deck never a problem
12-10-2017, 11:35 AM #4
Ok great, where abouts under the dash? Screw it down to the forward bulkhead? Does it need to be facing up? Thanks again!
12-10-2017, 11:50 AM #5
lightspeed, tux974 liked this post
12-11-2017, 12:35 AM #6
Ok great, Thanks for the advice!
12-11-2017, 06:36 AM #7
If you going under and can not find the bracket I use a small thin aluminum strip, bend accordingly to support it. Bracket is a good idea especially in a HPerf hangin and banging application.
12-11-2017, 10:25 AM #815.5 cobra 175 hp merc - sold
12-11-2017, 11:34 AM #9
12-11-2017, 05:41 PM #10
WTB LOWRANCE LGC-2000 GPS puck
By CircleHook in forum Parts WantedReplies: 0Last Post: 03-08-2017, 07:00 AM -
livorsi gps puck lifespan
By aggiestckl in forum Technical DiscussionReplies: 15Last Post: 03-31-2015, 06:23 PM -
GPS Speedometer Receiver Location Recomendation
By Pickinator in forum Electronics, Audio Systems, and WiringReplies: 9Last Post: 09-04-2014, 10:02 PM -
Gaffrig GPS Antenna/Receiver location??
By PORT in forum Technical DiscussionReplies: 1Last Post: 04-06-2007, 02:56 PM -
Gps Wiring & "puck"/head Location Questions...
By VELOCITOY in forum Technical DiscussionReplies: 6Last Post: 05-19-2003, 10:27 AM
