Results 1 to 13 of 13
Thread: Consumption data
12-09-2017, 04:31 PM #1Junior Member
- May 2006
- istanbul
- 9
Consumption data
Does anyone checked the link below about the fuel consumption?
Anyone compared the datas? Almost every low emision models are submitted.
http://www.boat-fuel-economy.com/evi...umption-liters
12-12-2017, 12:23 AM #2
If your into fuel economy on a boat, you better just buy a sail boat. expect 1 to 4 mpg.
12-12-2017, 12:15 PM #3Junior Member
- May 2006
- istanbul
- 9
When i retired will have lots of time, then i can sail with no time wory.
I use most expensive fuel in the world at my country. Abut 1,3 usd per liter
Any way, this research is not about economy. It is about planning long distance cruise with my boat powered by 225ho. And and i want to share some cool stuff, this forum is about that i think
Capt.Insane-o, tunnelmike liked this post
12-12-2017, 12:25 PM #4
Every boat is different. Your better off experimenting gallon by gallon. Then you will know how much your particular boat consumes
12-12-2017, 12:36 PM #5Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
Some Allison models with a new FI two stroke get 12mpg!
12-13-2017, 09:07 AM #6The Historic Photo Master
- Jan 2004
- Florida
- 37,836
- 64
- 1667
- 337
- 19216
- 3 Post(s)
As a very general rule, when I would design a new fuel tank or tanks for a new design outboard powered boat, I would directly relate the horsepower of the outboard(s) to the wide open throttle fuel consumption as follows: 200 h.p. = 20 gallons per hour, 150 h.p. = 15 gallons per hour, 300 h.p. = 30 gallons per hour...and so on. Note, this is for a single engine installation, so multiply accordingly. An outboard does not know what kind of boat it is on...it uses the same amount of fuel per hour when propped properly to its wide open throttle maximum rated r.p.m.
12-14-2017, 06:16 AM #7Junior Member
- May 2006
- istanbul
- 9
12-17-2017, 02:41 PM #8The Historic Photo Master
- Jan 2004
- Florida
- 37,836
- 64
- 1667
- 337
- 19216
- 3 Post(s)
you betcha
12-18-2017, 12:15 PM #97000 RPM
- Feb 2005
- seattle
- 2,654
- 17
- 33
the old "bass and walleye" mag posted that type of data. a 2004 200xs and gran sport allison w/ was the best with 7.5 at mid speed [40] and 3.5 at wot. my voyager with a 2004 200xs was 7.4 and 3.3. i dont see a 12mpg at least thru 2010 when the mag ended.
12-18-2017, 12:36 PM #10Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
The 12mpg is on the Allison site for the smaller hull.
SS 2000 super sport, independent tests.
12-18-2017, 08:19 PM #11Screaming And Flying!
- Jun 2007
- Singapore/Melbourne/Italy
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
I just got a price for 55gal of VP race fuel here in Singapore, over USD2000
I could use that in one hour in my F1 v8
12-18-2017, 08:51 PM #12
Only $8.00 per gallon in MN
12-19-2017, 07:10 AM #13
if maximum fuel economy is what your after you need to invest in a fuel flow meter and GPS to find the "sweet spot"for your particular boat. I bought one for my Lowrance HDS 5 and was quite surprised at what I found.
My boat is an Allison XB2002 with a 2001,totally stock,carb 200 Johnson.
Before I bought the flowmeter I would cruise at 45-50 mph thinking that was probably the most efficient speed. At this speed itwas showing a max of 4.3-4.7 mpg at a steady cruise. I found that increasing my speed to about 65 mph improved my mileage to nearly 6mpg. I verified this many times and found that I was averaging 4.5 mpg for the tank using both the Lowrance data and the old fashion method of topping it off and dividing the miles traveled by the gallons used.
On my Allison you can clearly feel it lifting at 60-65 mph. Hull is getting much drier and mre efficient at that pointLast edited by loop; 12-21-2017 at 07:02 AM.
limited skills
XstreamVking liked this post
Article: Livorsi's New Data Gateway Delivers CAN Bus Engine Data To Your NMEA2000 Navigation Device
By Scream And Fly in forum vBCms CommentsReplies: 0Last Post: 04-07-2011, 07:15 AM -
can anyone tell me fuel consumption on a 260 GPH?
By hst714 in forum Technical DiscussionReplies: 4Last Post: 08-31-2010, 10:15 PM -
300 XS Fuel consumption
By Adam Younger in forum Four Stroke and Direct Injected Two Stroke EnginesReplies: 8Last Post: 05-14-2008, 03:30 PM -
The joys of over consumption
By chris_lacey in forum The Scream And Fly LoungeReplies: 8Last Post: 12-28-2006, 08:49 PM -
Fuel Consumption I/O's vs. OB's
By Pro300x24LD in forum General Boating DiscussionReplies: 8Last Post: 07-24-2006, 12:05 PM
