Results 1 to 6 of 6
Thread: Trim/Tilt leaking down overnight
12-07-2017, 02:45 PM #15000 RPM
- Oct 2016
- Amityville, NY
- 176
- 27
- 13
- 73
- 127
08' 250xs Opti. Trim/Tilt leaks down overnight. I leave the motor trimmed up just a tad and the next morning the skeg is touching the ground. No visible leaks, pump and fluid reservoir are mounted in the boat and look OK. Do I need to repair this, and will it get worse if I don't? What's involved? Thanks.
12-07-2017, 06:29 PM #2
valves in the pump might have a slight leak, but overnight I guess you could expect a slight leak like that in a 10 y/o pump? Before you go pulling things apart I'd replace all the fluid with the correct stuff - could be some wrong viscosity stuff in there maybe, or condensation/gunk etc. Easy and cheap to try at least!
bouyhead thanked for this post
12-07-2017, 06:52 PM #3
Don't know a lot about the Opti's but if it has a manual release valve try opening it and run the trim up and down to flush it out some then close it and try it again...if that doesn't work it could be a ram leaking internally or a leaking internal valve/check valve. Just a couple of ideas anyway.
Hustler 15' Wildcat / Merc 80
Hustler 13' Wildcat / Merc 80
Hustler 13' Picklefork (Experimental) / Merc 80
Hustler 16' Victor / Evinrude 85
Hustler 15' Tunnel / Evinrude X115
Hustler 17' Lark / Suzuki 140
Ranger 17' Aztec / Merc 115
Hustler 16' Victor
Hustler 16' Victor / JohnRude 135 (current and restored)
Hustler 15' Family Tunnel / Johnson GT115 (current project)
Hustler 16' Victor
12-07-2017, 06:55 PM #4
try loosening the relief valve and then tighten it again, this sometimes does the trick.
or try tilting the engine up a lot more so there is a bit more pressure on the seal and see if this makes a difference.
how long as this been happening ?
12-07-2017, 07:18 PM #55000 RPM
- Oct 2016
- Amityville, NY
- 176
- 27
- 13
- 73
- 127
12-07-2017, 07:22 PM #6
me and DanUmbarger was posting and thinking on the same lines at same time ha ha
try what Dan says, its worth a shot before tearing into it.
Trim and tilt leaking internally possibly?
By 0081 in forum Technical DiscussionReplies: 2Last Post: 10-13-2013, 10:46 PM -
Mercury Tech: tilt/trim cylinders leaking
By ls7colorado in forum Technical DiscussionReplies: 24Last Post: 06-07-2009, 05:37 PM -
Tilt Leaking Down
By FOXCRAFT0923 in forum Technical DiscussionReplies: 6Last Post: 08-16-2008, 09:48 PM -
OMC V4 tilt cylinder leaking at pigtail
By Riverman in forum Technical DiscussionReplies: 3Last Post: 07-11-2007, 07:39 AM
