Results 1 to 12 of 12
    Jun 2017
    fife scotland
    Johnson V4 Crossflow recirculation system
    OMC recirculation system that is on v4 Crossflows.....what does it do, and what would happen if it was removed/plugged?
    On my motor (V4 1980 Crossflow) i have 4 check valves (Plastic ones mot brass as the norm) they are on the intake manifold below each carb.
    The check valves hoses lead to each by pass cover.
    Are these needed ? i have read that they help idling but i will be fitting CCM reeds so can i do away with these ?
    I love my Bikini
    Mar 2004
    Brooklyn Park, MN
    I have mine all pluged with a rubber cap on my motor and actually got some plugs for it as on one of my motors had the brass check valve and someone tried to solder it closed but it didnt completely plug it up. The threads are 1/4 pipe thread, you can get those plugs and do that to all of them as well. I think it was an EPA thing to try and drain extra oil/gas back into the motor to be burnt and not drip into the water.
    1973 Viper w/ V4 Crossflow.
    1978 Viking w/ 1978 175hp Merc, My first restoration in progress
  3. Thanks spybot thanked for this post
    Likes spybot liked this post
    Did you notice any issue with slow speed loading etc or doesn't apply to your usage?
    Jun 2017
    fife scotland
    Thanks RJ just the info i was looking for. Thats a good question FMP. Did the slow speed get effected ?
    I love my Bikini
    Mar 2004
    Brooklyn Park, MN
    Never had a motor with them in use. I was told they were just for EPA regulations. Older crossflows do not have them at all.
    Jun 2017
    fife scotland
    Anyone know what the UK equivalent is in BSP ?
    I love my Bikini
    Jan 2010
    Venice, FL
    Not an EPA thing.
  9. #8
    Jun 2017
    fife scotland
    Quote Originally Posted by 71V153 View Post
    Not an EPA thing.
    What does it do?
    I love my Bikini
  10. #9
    Singapore/Melbourne
    makes them idle properly
  11. Likes 71V153 liked this post
    Jun 2017
    fife scotland
    In what way ?
    If i add CCMS reeds will they not do the job better ?
    I love my Bikini
    Singapore/Melbourne
    its called the puddle drain system.
    it is designed to drain ( pumped via one way valves) any fuel away that puddles after the reeds at low speed and feed it back into the engine in a manageable way.
    It was changed over the years to make it work better.
  14. Likes 71V153 liked this post
    Jun 2017
    fife scotland
    OK i understand it now. I will have to look for two new plastic ones as two of mine dont work. May even have to bite the bullet and order 4 of the brass ones at 150
    I love my Bikini
  1. OMC Crossflow Recirculation Hoses
    By lance in forum Technical Discussion
    Last Post: 04-28-2008, 12:09 PM
  2. OMC V4 Crossflow Recirculation Valves
    By bang2568 in forum Technical Discussion
    Last Post: 01-15-2008, 11:23 PM
  3. OMC Crossflow Circulation System
    Last Post: 08-05-2007, 09:11 PM
  4. OMC Recirculation System??
    By imq707s in forum Technical Discussion
    Last Post: 06-29-2006, 08:43 PM
