Results 1 to 10 of 10
Thread: Jack plate ?
12-06-2017, 08:11 AM #1Member
- Jan 2015
- new hampshire
- 99
- 21
Jack plate ?
Going to re rig my 30 spectra this winter needs new jack plates, it has CMC hydraulic 10" set back on it now
05 300x
Any input on brand and set back would be great.
12-06-2017, 08:19 AM #2Screaming And Flying!
- 14,753
- 381
- 1305
- 5602
- 11033
Porta brackets if you want the best. They custom build each one for you.
12-06-2017, 08:45 AM #3
Lots of boats run Bobs. I have one on my 21 Skater and it works flawlessly.
12-06-2017, 09:31 AM #4
Shawn Torrente's are the latest and best non-hydraulic ones out there. All the X-Cat boat are using them as well as a bunch of guys running 400's. He will custom make them for you with any setback, color or logo you want.
bsboss liked this post
12-06-2017, 03:34 PM #5Member
- Jan 2015
- new hampshire
- 99
- 21
Any one have and experience with using more or less set back on this model
1998 Spectre cat
Twin 05 300x
spinning out
12-07-2017, 07:29 PM #6Supporting Member
- Apr 2003
- New Smyrna Beach, FL./LOTO
- 6,645
- 606
- 923
- 1699
- 7152
- 3 Post(s)
You don't need a lot with twin 3L motors. I had 6" with 260s and the boat was easy to balance out. I would go with the Porta Brackets so you can dial in your efficiency at your finger tips.
12-07-2017, 07:42 PM #7
why not just re-build the ones you have with nice new seals and bearings etc ? save a ton of money
12-08-2017, 07:21 AM #8Member
- Jan 2015
- new hampshire
- 99
- 21
The ones that are on the boat are a 10" set back most of the ones I have looked at have a much shorter bracket on them, the boat seems very flighty compared to another one I was in. Thought I would just ask the questions before I start on the project.
Thank you all for the input.
12-08-2017, 12:10 PM #9
Porta's are awesome, however in your case it might be too much setback and you may not need the mobility. I know a lot of setups with newer cats with big twins going this direction, the "set it and forget" setup.
Porta setback:
12-11-2017, 06:44 PM #10
Porta brackets are great or i recommend hydro dynamics
Bolt on cav plate and/or bottom plate on jack plate for an STV Euro
By Brookbbb in forum Props, Setup, and RiggingReplies: 9Last Post: 03-17-2017, 12:26 AM -
Rapid Jack Magnum 6" Jack Plate
By SouthernComfort in forum Misc. Parts and AccessoriesReplies: 1Last Post: 02-16-2016, 11:03 PM -
Manual Jack Plate vs Hydraulic Jack Plate
By Burchoid in forum Props, Setup, and RiggingReplies: 9Last Post: 05-25-2012, 05:00 AM -
Jack Plate Problem - Manual Rapid Jack
By croSSed in forum Props, Setup, and RiggingReplies: 0Last Post: 06-30-2008, 11:43 AM
