Results 1 to 12 of 12
12-04-2017, 02:40 AM #1
Wanting to rig 2x head temp gauges
G'day everyone, I've had a very reliable run with my old 2.4 Laser in my ski-boat so I figure I should do the responsible thing and rig some gauges so I can actually keep an eye on her properly!... I'll get a new set of Teleflex gauges and I'm just unsure of how to rig the temp gauges. I understand it's not a bad idea to have a temp sensor for each head (do it once do it right y'know!) - just not sure whether I should be monitoring water temp (tapping hole into heads) or fitting temp sensors into the factory plugs/holes in each head... which is preferred, and which sender units should I be using?
Thanks in advance guys
Gene
12-04-2017, 02:13 PM #2
Whichever floats your boat. I prefer just behind the thermostats.
12-04-2017, 02:15 PM #3
If you want to run 2 head temps I would tap for water temp that way you can still run the head sensor for the alarm. Just in case it gets hot and you not watching the gauges.
gmacrae thanked for this post
12-04-2017, 02:34 PM #4
Cheers guys, you wouldn't have any recommendations for a good web store for these bits would ya?
12-07-2017, 02:09 PM #5Screaming And Flying!
- 14,753
- 381
- 1305
- 5602
- 11033
They make a head sensor with the alarm and the temp readout function in one unit. For a 3 liter motor like an opti? Not 100% sure it works but should..http://www.ebay.ca/itm/Temp-Sensor-4...tZzBIT&vxp=mtr
Dave Strong liked this post
12-07-2017, 02:20 PM #6
http://www.aircraftspruce.com/catego...es_falcon.html
The sensors go in place of the spark plug washer. one on #5 and one on #6 should keep you well informed.http://www.aircraftspruce.com/pages/...robes/gem6.phpLast edited by dwilfong; 12-07-2017 at 02:28 PM.
WillySteve liked this post
12-07-2017, 02:31 PM #7
12-07-2017, 03:06 PM #8
12-07-2017, 04:13 PM #9
I see! 2 gauges in the one is a tidy/simple way of doing it for sure. I'm looking to use the sierra gauges I've bought though (finally doing a nice gauge set and stainless gauge panel to make it all look swanky)
12-07-2017, 04:53 PM #10
12-07-2017, 06:53 PM #11
I did wonder if 2 water temp gauges might be a little overkill, but they're ordered now... Will investigate those little temp probes though, would be cool to see if I can run them with the sierra gauges to show head temp without having to drill into the head, J type thermocouple has been mentioned for both I think, would be interested to see if the resistances are similar/compatible
12-07-2017, 07:28 PM #12
dwilfong liked this post
Left and right cylinder head water temp gauges
By racer7x in forum Electronics, Audio Systems, and WiringReplies: 6Last Post: 09-10-2013, 07:52 PM -
Mercury Tech: Water Temp/Engine Temp Gauges
By FisherBoats in forum Technical DiscussionReplies: 2Last Post: 04-11-2012, 08:29 PM -
Head temp OR water temp
By Ted Stryker in forum Technical DiscussionReplies: 0Last Post: 06-12-2007, 10:51 PM -
Temp sensor for OMC - water or head temp?
By STV_Keith in forum Technical DiscussionReplies: 6Last Post: 06-12-2006, 11:45 PM
