Results 1 to 2 of 2
12-02-2017, 11:26 PM #15000 RPM
- Oct 2015
- Kentucky lake
- 480
- 31
- 15
- 60
Steel bore engine on one piece plate ?
Is it OK to run a steel bore 2.0 on a one piece plate that's dry stacked and is tunable as far as water exit speeds ,no poppit valve and put 1/8"washers in heads ... just watch temp gauge and give plenty of warm up time???
12-03-2017, 02:32 AM #2
Yes
just play with the dumps with different fittings till you get the temps where you want them.
texasvector liked this post
Steel bore 260
By xpressman al in forum Technical DiscussionReplies: 4Last Post: 10-13-2014, 02:03 AM -
2.5 steel Bore Cases
By 86vintage in forum Parts WantedReplies: 2Last Post: 10-23-2013, 06:48 PM -
Chrome bore on 1 piece plate help!!!!!!!!
By Reaction19 in forum Technical DiscussionReplies: 14Last Post: 04-19-2012, 08:06 AM -
Mercury Tech: How to install 2 piece adapter plate and engine block.
By bigboy in forum Technical DiscussionReplies: 1Last Post: 05-17-2010, 03:25 PM -
260 steel bore????
By twig in forum Technical DiscussionReplies: 15Last Post: 07-27-2009, 10:13 AM
