Results 1 to 3 of 3
12-01-2017, 04:09 PM #1
Leak down tests pressure and time ?
When doing leak down tests on your engines what time periods are the tests done over ? 20 minutes ? 1/2 hour 1 hour ?
and at what pressures do you use for testing ( 2 strokes only please ).
what is considered an ok amount to leak down over such periods..
12-02-2017, 12:30 PM #2
You adjust the supply air to read 100psi, look at the other gauge if it says 90 you have 10% leak down. No need for a set time if leaks it leaks 10% or more teardown time.
hydrostreamvking4m, vnemous liked this post
12-02-2017, 01:32 PM #3James H. W2F a V-King... Want 2 Fly a V-King
Dave Strong liked this post
How much run time before leak down test
By CircleHook in forum Technical DiscussionReplies: 9Last Post: 07-05-2017, 04:25 PM -
3rd time apart water leak OMC, pics
By xp175 in forum Technical DiscussionReplies: 11Last Post: 06-02-2006, 03:49 AM -
1'st tests on the 115 PH.
By Clams Canino in forum Technical DiscussionReplies: 1Last Post: 08-04-2002, 10:13 AM -
fuel pressure leak. anyone??
By TD in forum Technical DiscussionReplies: 1Last Post: 05-31-2002, 05:35 AM -
the TESTS are in!!!!
By 2.5-21 in forum General Boating DiscussionReplies: 41Last Post: 04-05-2002, 11:54 PM
