Results 1 to 10 of 10
11-27-2017, 12:13 PM #15000 RPM
- Sep 2017
- Saugatuck, Michigan
- 318
Test wheel / prop for 225 Johnson, 1989
Have 1989 omc 225's...need test wheel
734-578-2815
Thanks, Bart
11-28-2017, 05:26 PM #25000 RPM
- Sep 2011
- Deplorableville
- 740
- 1347
- 76
- 3211
- 1452
Man, I went through all of this a few years ago. Good luck finding one of those uncorns these days. If you do find one, they are very pricey. Do you have a coned lower with low water pickups?
11-28-2017, 06:01 PM #35000 RPM
- Sep 2017
- 318
Yes I have Bob's.....
pricy is right,around $200, just thought someone might have one laying around.
Going to do it at the ramp, boat on the trailer with the props I run.
It's only 5 to 5500 for a short burst
Thanks for the response
11-28-2017, 06:03 PM #45000 RPM
- Sep 2011
- Deplorableville
- 740
- 1347
- 76
- 3211
- 1452
I found that you need to hold it there for a bit and kill it, it only takes a few seconds as it comes down in rpms to give you a bad read.
11-28-2017, 10:00 PM #55000 RPM
- Sep 2017
- 318
I'm going to have a cert outboard mechanic on board... I will run the throttle to instructions.
All good
Thanks for the info bullet
B
12-16-2017, 09:05 PM #66000 RPM
- Calgary, Alberta
- 1,123
- 21
- 58
- 341
- 174
If you watch EBay they do come up a couple times per year.
Matt
12-16-2017, 09:47 PM #75000 RPM
- Sep 2017
- 318
Thanks Matt
12-21-2017, 12:24 PM #85000 RPM
- Henderson NV
- 100
Tightrig
I have had the same problem, I learned from an OMC tech that you can take a regular prop cut half of each blade off, rebalance and it works great--as a test wheel it ventilates enough to get most any rpm, but still loads down the motor, if not enough load leave more blade area on the next one. We use damaged props that would normally end up in the recycle bin so the cost is small. I have some with different hubs in the shop when the need arises for different motors.
Kevin
R&R Prop Shop
12-21-2017, 01:13 PM #95000 RPM
- Sep 2017
- 318
Thanks Kevin...
We just did mine at the launch ramp a couple weeks ago. Left boat on the trailer, ran 1 eng at a time up to 5000 rpm in gear with mechanic on the timing light. Ran with my mazco 28 prop. Had to repeat a few times on each motor.
Boat feels like to wants to jump off the trailer, a little scary but we got the job done.
Stb motor ended up being way retarded...went from 5600/5800 rpm wot to 6000/6200. Picked up 5mph.
05-10-2018, 07:33 PM #10
Need test wheel / prop for omc 225
By Tightrig 12 in forum Propellers WantedReplies: 2Last Post: 05-11-2018, 10:17 AM -
Where to get a test wheel/prop for OMC
By kimswang in forum Technical DiscussionReplies: 6Last Post: 08-16-2007, 10:35 AM -
Test prop/Wheel ??
By inspectorlance in forum Technical DiscussionReplies: 3Last Post: 04-25-2006, 01:48 AM
