Results 16 to 30 of 31
    May 2017
    Ca
    Possibly but the one that killed itself on my motor was painted black and defiantly only had one crank bearing.
  2. #17
    Tampa, Fl
    Now that I think about it, the new compressor was made in USA and the original was made in Mexico. It was several years ago that I went through this, my memory isn't what it once was.
  3. Likes NICE PAIR liked this post
  4. #18
    Replace the oil line filters as well. Or, at least inspect them carefully. Oil flows in and out of the compressor.
  5. #19
    May 2017
    Ca
    10-4. Are there filters besides the screens on the brass 90įs for the return lines?
  6. #20
    Small white plastic filters with directional arrows on them. On the oil supply lines. Also,I guess you know to prime the oil system and go back into break in mode for the new compressor?
  7. #21
    May 2017
    Ca
    ya my buddy is a Merc tech he’s going to hook it up to the computer and prime the pump and all that and run it on the dyno.
  8. Likes NICE PAIR liked this post
  9. #22
    May 2017
    Ca
    Got it all back togethor. So I was going to take it to the dealer my buddy works at to have the oil line primed and whatnot and found out the compressors come oiled from the factory? Should I fire it up or what and spend the money and have the Merc tech fire it for he first time
  10. #23
    Oct 2016
    Long Island, NY
    After replacing my compressor and all the oil filters I primed the pump/lines/compressor. You can prime everything by putting the engine back into break-in mode. Turn ignition key to on position then shift in and out of forward 3-5 times. you'll hear the pump run for a bit priming the whole system.
  11. #24
    May 2017
    Ca
    Quote Originally Posted by bouyhead View Post
    oh about those filters, I didnít find any. The two return lines went straight from the compressor to top and bottom crank bearings. Only filters I found were very fine screens in the brass 90į fittings coming out of the compressor for the return lines. Also there was a one way valve going from the fuel rail air side to the end of the vst. I cleaned that out. See picture
  12. #25
    May 2017
    Ca
    The diagram for my serial number also doesnít show any filters.
  13. #26
    May 2017
    Ca
    These are what the old compressor had. In place of these white filters I keep hearing about. Now Iím wondering if the new style compressor I got has these or if I need to get the white filters.
ID:	394424   Click image for larger version.
  14. #27
    May 2017
    Ca
    AnyoneHave any insight before I fire this thing up
  15. #28
    May 2017
    Ca
    You have mentioned a number of times you have a buddy who is a merc tech. Whats he say and why arn't you following his recommendations? Just curious.
    I haven’t asked him about the oil filters yet.
  16. #29
    May 2017
    Ca
    Took it down to my buddy at the Merc dealer. Hooked it up and tested the injectors and number 4 wasnít firing. Guess thatís what I get for being impatient and sending them local when I should have sent them back east. Canít swallow 485$ for a new one so back to eBay it is. This is getting expensive lol
  17. #30
    May 2017
    Ca
  1. Optimax compressor
    By xb03fs in forum General Boating Discussion
    Last Post: 06-18-2017, 08:55 PM
  2. Mercury Tech: 2005 optimax 175 HP, compressor failure, how to clean air injectors?
    By Sparkieboat in forum Technical Discussion
    Last Post: 05-05-2016, 10:06 AM
