Page 2 of 2 FirstFirst 1 2
Results 16 to 26 of 26
    Aug 2009
    mpls,mn
    10-4 brother it just don't make sense ? Were trying to do the almost same thing here but we get ice LOL so we use it in our drinks hibernate with mama and test in spring .
  2. Likes rjdubiel liked this post
  3. #17
    Jul 2014
    uk
    Interesting thread. I am toying with removing 5.5” setback on my 8metre stepped hull. Worried I’ll loose speed. Surely the weight of a bracket has some negative impact too? Prop runs level with rear hull and runs fine. Needs tabs to plane though.
    Only reason I want to remove is cause I can’t trim the engine up out of the water. And it will spend some time living in the water this year. Surely someone done a direct comparison.
  4. #18
    7 Post(s)
    Ended up w/8" on my Vector. That was w/a slimmed down OMC looper, but probably still 50 lbs heavier than your motor.
    That was where it was at at 101.
    Motor was 2" bellow though.
    That rig did lots of the things the experts said wouldnt work, including that much weight, that far back.
    To me, set back is really basic.
    Have a friend get a really good/close up shot or video of you at WFO.
    If you have ANY up trim in the motor, as in, beyond vertical w/the water line, regardless of where the hull is, you need more set back.
    Mine did everything well at 8", Id say you could do that or 10".
    That was also w/a 543 lb (bare) hull too. So if yours is heavier, it would require more to see same result.
    Checkmate 16' 140 Johnson
    Laser 480 (?) 21' w/GT 200
    24' Sonic w/twin 250 Johnsons
  5. Likes Dave Strong, texasvector, Jimboat liked this post
  6. #19
    Aug 2012
    beaumont, tx
    i tried closer setback since this thread.....problem was i couldnt get motor low enough.....bottomed everything out and i was still 3/4" above pad....2" back it wouldnt pick bow up with any prop......if i could get closer i think i could be faster
    at 6" back i never have posaitive trim.....even at WOT with nose flyingClick image for larger version.
    i changed props and got nose down
    im dead even with pad at 6" back
  7. #20
    Aug 2009
    mpls,mn
    since this thread im running a v-4 on the 16ft Allison 5 in set back,but now im building a 200hp merc v-6 for it with cut down 15in mid so now it will be a totally different boat come spring so now I will start with the same 5 in set back and go from there. Im thinking closer than farther but will have to wait its cold as hell out LOL
  8. #21
    Aug 2010
    tennessee
    cody post a picture of mine running the 6inch setback and 20inch mid on my comp vking ... mine runs nose high with one prop next prop runs flat ... 26 hoss triton and 260 trim down to gain speed .. 30p hoss triton trim up to gain speed ... lol idk
    2001 american offshore 26 twin 300 promaxs
    2006 hydrostream comp vking horned 225 promax/
    1979 hydrostream vector sold
    1986 23ft twin engine eliminator twin 225 promaxs SOLD
  9. Likes texasvector liked this post
  10. #22
    Quote Originally Posted by 265mercman View Post
    Not much different than Cody'z or anyone else's boat. They are all different and like special things.
  11. Likes texasvector liked this post
  12. #23
    Scribed
  13. #24
    Jul 2009
    Crawfordville fl
    I think u can work with a prop guy and make it work either way A good prop guy can totally change the characteristics of a prop.
    Nitrous is like a slut. u wanna hit it but you know there will be consequences.
  14. #25
    Dec 2011
    Ludington michigan,on the shore
    Mine runs best @ 1 1/2 to 2 degrees negative. I'm 1/2 inch back,and 1/2 inch above,running a 26 Tillman Yamaha.Runs flat,0 to 100 quick,and never touch the trim.
  15. Likes W2F a V-King, texasvector liked this post
  16. #26
    Aug 2012
    beaumont, tx
    been a year...since ive taken a lil lip of the pad (about .010") and was able to raise motor a tad (around 1/4" above now)
    the ET has been the ticket on keeping bow down with plenty of lift.. low rake!
    still believe i could benefit if i went closer with motor but setup wont allow me to get motor low enough. and if i went farther back it would only cause more negative trim.
    best yet 105.1mph
Name:	Screenshot_20181218-162341_Digital Dashboard GPS.jpg
    i also tried a prop spacer last time out.....slip numbers went down and speed went up
  1. 22' Stoker, How much setback? I need speed damm it!
    By AzDesertRacer in forum Props, Setup, and Rigging
    Last Post: 07-24-2014, 11:59 PM
  2. Setback effect on blowout speed?
    By aaronmt73 in forum Props, Setup, and Rigging
    Last Post: 07-28-2013, 11:18 PM
  3. How much speed and how much setback???
    By HOT H2O in forum The Scream And Fly Lounge
    Last Post: 01-08-2005, 06:18 PM
  4. jack plate setback vs. speed gain?
    By 1000yards in forum Technical Discussion
    Last Post: 09-23-2004, 03:06 PM
