Results 1 to 6 of 6
11-21-2017, 05:57 PM #15000 RPM
- Mar 2012
- Lake Hopatcong, NJ
- 218
- 31
Any way to repair loose splines on a 2 piece 3.0L driveshaft?
I have a 3.0L lower with the 2-piece driveshaft, 20", and the lower splines are loose enough that the shaft rattles at low rpm. It's a 1.62 Sportmaster that works great other than the rattling. Any other solution out there other than replacing the whole shaft assembly? That would cost more than the lower is worth, I think...
11-21-2017, 06:58 PM #2
a stainless 20" driveshaft and install is much cheaper than your lower unit JMO
Call the number in my signature and George will give you a quote.Last edited by vnemous; 11-21-2017 at 07:01 PM.
11-21-2017, 07:08 PM #3
Clean it up and have someone weld it together if you dont wanna replace the shaft....However....Its not terribly expensive to replace the drive shaft with a one piece stainless one....I guarantee your seal surface below the water pump is not long for this world if the rest of the shaft looks like that.....
1984 28 ghost twin 200 Yamah ProVs (SOLD)
1997 21 Superboat Legend 250 VMAXXX (SOLD)
2001 25 Concept CC 250EFI (SOLD)
2002 24 Superboat Step 250EFI (SOLD)
1997 21 Checkmate Pulsare 200EFI Merc (Beater Boat)(SOLD)
1994 20 Hydrasport 225 Optimax (SOLD)
1998 27 progression Twin 225 Mercs (SOLD)
2005 23 Kryptonite 300 Promax (SOLD)
11-22-2017, 12:05 PM #45000 RPM
- Mar 2012
- 218
- 31
The whole lower is kinda old and you can see the condition, so I'm hesitant to spend big money fixing it. Will look into the one piece shaft. The stock parts are like $1400 for both shafts and the coupler plus install.
11-22-2017, 01:19 PM #5
20" driveshaft is about $400.+bearings, reseal and labor.
11-26-2017, 05:13 PM #6Screaming And Flying!
- Dec 2001
- 9,502
- 271
- 191
- 1976
Did someone say cheep or easy?????Degrease it and MarineTex....or 5200....I had a guy with a old L6 merc and NO splines....MarineTex worked.... for a crabber....harder on stuff than racers. 5200 would be more forgiving if not set right ....rubber wobble. Had a 25 rude with bad upper mounts. Had job with broken bolts ect. Used 5200 on searing yoke to Exhaust mount area.....worked like new or better than omc small mounts.
Driveshaft splines
By ChrisCarsonMarine in forum Technical DiscussionReplies: 2Last Post: 07-31-2010, 07:22 AM -
merc driveshaft splines...
By lokinutz in forum Technical DiscussionReplies: 1Last Post: 10-02-2007, 11:43 AM -
driveshaft splines
By Stretch in forum Technical DiscussionReplies: 0Last Post: 01-14-2007, 06:10 PM -
Driveshaft retainer nut coming loose
By Capt.Insane-o in forum Technical DiscussionReplies: 2Last Post: 01-12-2003, 12:50 PM
