Results 196 to 210 of 247
12-31-2017, 11:02 AM #196
Thank-you Chaz.
A bazillian years ago, when I was a child, I had a Bultaco (Serpa S) motorcycle.
It is a real pipey 2 stroke and has light switch for a throttle.
It idled fairly fast and had a power band about 14 rpm wide and that happened around 9,000 rpm. (numbers could be slightly adjusted to enhance story)
We rode as a group and did a lot of trail riding and hill climbing and the light switch bike just wasn't fun.
Soooooo, I cut the chamber off, ran a 2" pipe from the head back past the foot pegs and off we went.
Absolutely -0- top end but you could pop the clutch @ idle and it would chug away. It would go flat about 1/2 way to its top horsepower
I'm thinkin this thing needs some squeeze like the expansion pipe and stinger puts on it. I reach back with my foot and cover up most of the end of the pipe and the bike starts rolling, the tighter I squeezed it the higher the rpms went.
Yahoo! I had an adjustable stinger exhaust in 1963, I wonder if I could market it. (I'm gonna need better leather for my boots.)
If you held the motor squeezed and max rpm long enough it would overheat and stick the piston, If you clutched it early enough, the air going over the barrel would cool it enough for it to come loose.
Just some of the dumb **** you do when your a kid.
Don't try this with your outboard. ;-)Wriggleys gum makes me think of boating, "Double your engines, Double your fun"
olboatman liked this post
01-01-2018, 09:38 AM #197
Nice Pair , nice response , really nice practical reason that some don't get it . They have never spent much , if any time on "pipey" 2 stroke motorcycles .
No amount of pages of text will be able to explain the difference between the feeling of a "droning open megaphone" and that of one that "comes on the pipe" and tries to throw ya off the back ...
( I remember sitting in the McDonalds {1976} on Van Nyes Blvd. and looking across the street and seeing Steve's Bultaco and Hank the Crank's shops were next door to each other and thinking , somehow I thought they would be bigger )
cemoto
A little more bell mouth this time ... >
01-01-2018, 12:33 PM #198
01-01-2018, 02:47 PM #199
It's "nice" of you to say that ...
Speaking of that , when I bored the sleeve registers to final size . I looked down the hole and said ... These babies could easily go out another "hunnert fitty thousandths" ..
To do so would require the outside to either be all welded up or epoxied to where I could get enough depth to the port runner to feed a 667 cc cylinder . Not that would be a totally bad thing . But it would definitely take away the relatively stock looking outward appearance ..
As it stands (for) now . With a 3.0L crank they are 3462 cc and with a 3.2 crank they come out to 3642 cc's with more than enough runner depth and width to support either a 577 or 607 cc cylinder without having to get too crazy ..
Next in line was the "oversized" billet blocks I had machined up . It takes some work to get them to fit the front half , but nothing too hateful . I wanted to open the hole up anyway . As the rod is moving away from BDC , it's size and angularity does a good job of blocking the only way in ...
Chris Carson made up the tooling and ran a few sets of reeds for me that fit perfectly ...
01-01-2018, 03:41 PM #200
01-01-2018, 04:16 PM #201
NICE PAIR thanked for this post
01-02-2018, 08:40 AM #202
01-02-2018, 09:20 AM #203
01-02-2018, 09:23 AM #204Scream And Fly VIP
- Jul 2013
- California
- 1,555
- 21
- 63
- 83
- 294
Unless you have a calibrated accelerometer up your butt!
01-02-2018, 09:42 AM #205
Which one is johnny?
Attachment 396033Wriggleys gum makes me think of boating, "Double your engines, Double your fun"
01-02-2018, 09:44 AM #206
01-02-2018, 10:24 AM #207
Never said 5 and 6 was the weakest, said that they wouldn't get any of very little available stuffing. The point was these motors are more about scavanging which goes along with your statement. 5 and 6 get the best scavanging and least stuffing which is why I claimed are the ones that get fried the most.Last edited by FORBESAUTO; 01-02-2018 at 11:14 AM.
01-02-2018, 11:21 AM #208
01-02-2018, 06:35 PM #209
It would look like two of them stacked on top of each other . One with butterflies , the other with the butterflies removed . So I would say , not very good .
I'm a big fan of all the cylinders drawing air from a common area after it is metered .
I have some of the parts complete to build a sheet metal plenum with the air inlet out front . But that is a "down the road" project .
01-02-2018, 07:11 PM #210
Does the inlet being at the top have different effects for the closest ports as opposed to the furthest(bottom) ports, or is the plenum pretty much equal for all? I've seen on some race manifolds for autos how they sort of collapse the plenum down towards the rear. What would be the purpose there?
Trust me I'm an Engineer (funny pics)
By Stitch King in forum The Scream And Fly LoungeReplies: 3Last Post: 11-14-2012, 08:13 PM -
New show. American Inventor
By WILDMAN in forum The Scream And Fly LoungeReplies: 0Last Post: 03-16-2006, 07:49 PM -
AutoCad and Inventor
By Fibertron in forum The Scream And Fly LoungeReplies: 31Last Post: 11-30-2004, 09:05 AM -
Anyone know the designer of
By Dukeofchippewa in forum Outboard and Racing HistoryReplies: 0Last Post: 10-03-2004, 11:43 AM
