Results 1 to 15 of 103
Thread: Building a 10' dinghy/tender
11-19-2017, 04:37 PM #1
Started this project a while ago but got busy w/other things and never had time to work on it.
Going to hang on davits on the back of our cabin cruiser on Lake Erie.
Had a 10' Zodiac but was a PIA when you really use it like we do.
Found a set of plans on Glen L.com that was close to what I wanted. I inset the motor boar to keep overall length at 10' to match the transom of our cruiser. Any longer and it sticks past the sides of our hull and will snag entering/leaving dock.
Building it form 5 ply, 1/4'" Okume marine plywood.
Ive built a bunch of plywood boats but never w/this much curve. In theory, a panel will bend side to side or end to end but not both.
That is a compound bend/curve. The side of this boat have a ton and I almost passed on it cuz I didnt think it would work.
The pc on the transom is only there to hold everything square until the skin goes on.
Target weight is 100lbs.
I have a 35 hp motor for it that I just went through and painted.
Should run good.
We are moving in 3 wks and I lose my shop so I am under the gun. The skin went on this weekend.
Last picture is this design, framed for a full deck. Mine will be mostly open.Last edited by Instigator; 11-19-2017 at 04:51 PM.
Checkmate 16' 140 Johnson
Laser 480 (?) 21' w/GT 200
24' Sonic w/twin 250 Johnsons
Capt.Insane-o, 89LASER, tunnelmike, Scream And Fly, WillySteve, specboatops, Forkin' Crazy, tux974 liked this post
11-19-2017, 04:44 PM #2Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
10' +100lbs+35HP= some kind of fun , white knuckles maybe.
DanUmbarger liked this post
11-19-2017, 05:04 PM #3
Yep.
Built one yrs back that came out closer to 150 lbs and ran a 15 on it and it was a hand full. We knee boarded behind it.
If I can make it work, I want to install cable steering in this one due to expected speed but my davits are only good to 300 lbs so Ill be pushing it.I'd rather be competitive w/junk I built in my garage than win w/stuff I bought.
11-19-2017, 05:16 PM #4Team Member
- Lake Coochiching, Ontario
- 7,766
- 276
- 487
- 1590
- 6 Post(s)
It's that a TNT?
11-19-2017, 05:17 PM #5
A fun/learning part of installing the skin was learning to do a scarf jont. Ive done them before but never 48" long and on 1/4" plywood.
It calls for a 12:1 ratio (12 x 1/4") so that made the joint 3" wide.
I make my own glue by mixing polyester resin w/Cabosil and 1/8" glass fibers.
Having problems loading pixs but was able to bend a strip in a 18" radius before it fractured and the glue joint remained in tact.
Way impressed.I'd rather be competitive w/junk I built in my garage than win w/stuff I bought.
11-19-2017, 05:19 PM #6I'd rather be competitive w/junk I built in my garage than win w/stuff I bought.
11-19-2017, 11:41 PM #7
Damn!! That things gonna move with that 35. I have an 8ft wood skiff at 80lbs and that is pretty quick with a 15.
Instigator liked this post
11-20-2017, 02:52 AM #8
I hate to tell you that motor is waay tooo big for that bathtub so what do you want for it... Motor looks amazing gary.. Its gonna be a handful .
11-20-2017, 12:22 PM #9The Historic Photo Master
- Jan 2004
- Florida
- 37,836
- 64
- 1667
- 337
- 19217
- 3 Post(s)
Gary. Please don't use polyester resin as glue. No good for that.
11-20-2017, 12:36 PM #10
WOO HOO !!! More little boats!!! Looking great.
Is that motor restored? or that clean original?1) 1995 14' Bayliner Restoration <--Click
2) Home-Made Tunnel-Boat Project <--Click
11-20-2017, 01:18 PM #11
11-20-2017, 05:28 PM #12
More headway.
Sides and bottom are skinned.
If all goes well tomorrow it will get a coat of stain.
Ordered 3 qts of Epithane varnish today.
Short wk this wk but hopefully by mid next wk it will come off the jig and be righted.
Then I'm throwing the jig on the burn pile and lighting it!
Sick of walking around the damn thing.
Anxious to see it right side up.I'd rather be competitive w/junk I built in my garage than win w/stuff I bought.
11-20-2017, 08:02 PM #136000 RPM
- Calgary, Alberta
- 1,123
- 21
- 58
- 341
- 174
Brabender liked this post
11-21-2017, 07:57 AM #14
I think you guys are thinking of the micro ballon powder additive.
It adds viscosity for use as putty and the micro balloons makes it easy to sand but is for cosmetic repairs only.
Conversley, Cabosil and the like, adds viscosity and density. Now add 1/8" milled fiber, as in, 1/8" strands of glass and now you have something.
Of all the tricks I've learned working w/glass, this is my favorite.
Perfect for building fillets where stringers meet the bottom, filling voids around a new transom core etc.
Alter the amount of Cabosil to change consistency from glue to putty.
While in Fla I tested it. I took two pcs of scrap plywood, glued them together and threw them out in the yard for a yr.
The wood broke down, the glue did not.
Heres a challenge for you:
Take two 12" x 12" pcs of 1/4" plywood, good 5 ply mahogany, w/no voids (not the 3 ply fir crap at the hardware stores) and mix a Dixie cup of the cheapest polyester resin you can find, mix enough Cabosil to get a mayonnaise texture. Now add a golf ball size amount of 1/8" milled fiber and mix.
Now spread your mixture one one of the panels. Instructions would say to coat both but I'm confident enough that one will work.
Now put the two panels together and set a concrete block on them to act as a clamp.
Tomorrow, after your morning coffee, pry the panels apart w/o destroying them.
Then post pixs of your results here.
Do that w/o destroying them and you'll have my attention.I'd rather be competitive w/junk I built in my garage than win w/stuff I bought.
Capt.Insane-o liked this post
11-21-2017, 08:28 PM #15Screaming And Flying!
- 14,753
- 381
- 1305
- 5602
- 11033
If it breaks, he knows someone that can fix it......
Just a little dinghy..............
By Instigator in forum General Boating DiscussionReplies: 70Last Post: 05-24-2023, 10:48 AM -
Tender for the LCB
By bretter in forum General Boating DiscussionReplies: 23Last Post: 11-07-2014, 06:21 AM -
Anyone here use a Battery Tender or similar device?
By LakeRacer99 in forum Technical DiscussionReplies: 11Last Post: 02-15-2006, 11:26 PM -
re building 260
By big poppa pump in forum Technical DiscussionReplies: 2Last Post: 10-01-2004, 07:56 AM -
building new shop looking for a steel building
By eautosales in forum The Scream And Fly LoungeReplies: 12Last Post: 12-15-2002, 09:32 PM
