Results 1 to 15 of 26
    140 V4 Cross-Flow Port timing #S
    Looking for the factor port timing #s for a stock cross-flow 140 for a member to compare to his 85hp?
    Thanks Gary
    Aug 2009
    mpls,mn
    gary I sent you a pm on this you not get it ? I don't have the #s but I think I have a 115hp block I can measure same as a 140hp he can open the ports up and square them off but do not raise or lower them for what he is doing.It would be very easy to make that 85hp a 140hp as its a 3.5 inch bore block .With the 1-5/16 carbs with 67-68 main jets a bubble back exhaust and the port work its a 140hp easy build and he wout have to mess with the tuner LEAVE THE TUNER STOCK than he will have a great motor for his application.
    I didn't see the pm Ken.....I told him what you told me on the phone( not the tuner as I will pass that along) and FMP was lookin for the port timing #s in case he didn't have the big bore to compare to.
    Gary
    Aug 2009
    mpls,mn
    ports 115-140
    Lucky I did not scrap it yet.So 115-140hp are the same ports.If you look close you see the ports come close to each other only about 1/16 th on an inch between them intake and exhaust.So intake : top of cylinder to top of port 2.100 top of cylinder to bottom of port 2.950 exhaust: top of cylinder to top of port 1.750 top of cylinder to bottom of port 2.635 that's inches and thousands your over seas so if you want metric you convert it.If you just make the ports round you got 115-140 stock ports if you make them square it will breathe better than stock.Dont raise or lower the ports or you will end up with a new anchor.Do all the mods and that 85 hp will come to life big time.Hope that helps.
    Attached Thumbnails Attached Thumbnails IMG_1951.jpg   IMG_1952.jpg   IMG_1953.jpg   IMG_1954.jpg
  5. Thanks spybot, olboatman thanked for this post
    Likes spybot, spucky liked this post
    Nov 2013
    Oak Hill Fl.
    Guys call LA sleeve and talk to the tec line guy. He can send you the blue prints for what ever sleeve you want to compare what ever.
    Aug 2009
    mpls,mn
    You don't gots to get that technical man.Just do what I posted and be done with it.Sure you can get la sleeves blue print and your sure not going to port that motor by hand to the exact dimentions so write a cnc program for your cnc machine and get it exact or just port it and have a good motor the cheap way ? JMHO no harm intented.
    Jun 2017
    fife scotland
    Thank you racervboat. i now have all the info i needed plus some good advice
    Andy
    I love my Bikini
  9. #8
    Jan 2010
    Venice, FL
    Quote Originally Posted by racervboat View Post
    Well that or ya could dig up a decent 115/140 block and square up the ports a lil ...
  10. #9
    Aug 2009
    mpls,mn
    IF I port this junk block to race mod specs will anyone give me the coin for the work and put 4 new sleeves in it and redo the porting again ? im a seller if your a buyer.AND THE BASIC BLOCK IS FREE.What a bargain for me OPP I mean you hahahahaha
  11. #10
    I got a 84 140 that sucked a ring and need to have you rebuild it for my Carlson . Gonna ship it out( power head) in the create you sent the beast in. Might need that block??? Just need some time to get her in the garage to pull it.
    Gary
  12. #11
    Catch ya tomorrow nite.....gutta go.
    Gary
  13. #12
    Aug 2009
    mpls,mn
    Ok bro will do your block not that one I got its a scrapper.
  14. #13
    Ok so what are the degrees duration?
  15. #14
    Aug 2009
    mpls,mn
    27 and partly cloudy with 25 mph winds?
  16. #15
    Not bad , we're pushing 30-35knots. What's the blow down on the 140?
  1. OMC Tech: Transfer Port Openings 150 Cross Flow
    By LSaupe in forum Technical Discussion
    Last Post: 04-23-2011, 05:41 AM
  2. Timing an OMC Cross-Flow
    Last Post: 04-13-2009, 05:00 PM
  3. Omc 25 H.p. - Cross Flow-
    By DonChicho in forum Technical Discussion
    Last Post: 08-01-2006, 09:13 PM
  4. OMC 175 cross flow
    By Dogboy in forum Technical Discussion
    Last Post: 06-24-2005, 06:30 AM
  5. Cross flow
    By woody in forum Technical Discussion
    Last Post: 06-07-2003, 10:25 PM
