Results 1 to 4 of 4
11-15-2017, 01:57 PM #1New Member
- Nov 2017
- maryland
leaking at motor mounts is this normal?
1999 Mecury 250 on the hose, we notice that we have water leaking out at the lower motor mounts
Also There is a very strong stream from the mid dumping on the cavitation plate.
Pisser is strong, motor not overheating.
So, is this normal or a problem.
thanksLast edited by davidBoater; 11-15-2017 at 02:13 PM.
11-15-2017, 02:12 PM #2Screaming And Flying!
- 14,753
- 381
- 1302
- 5602
- 11031
Lower motor mounts? I have one that does that, has for years. Prob needs a base gasket...2 others that do not. Run the same temps.
11-15-2017, 03:30 PM #3
Both my 3 liters leak water around the upper mounts. 250efi and 300x No overheating problems.
11-15-2017, 03:34 PM #4New Member
- Nov 2017
- maryland
This leak is the lower mounts. I posted vids on the single outboard facebook page. https://tinyurl.com/y8gjtsel
Mercury Tech: 2.4 new top solid mounts leaking a bit
By rvaha in forum Technical DiscussionReplies: 0Last Post: 08-17-2009, 10:24 AM -
Water leaking around upper mounts 2.4
By hydrostreamvking4m in forum Technical DiscussionReplies: 5Last Post: 04-16-2009, 09:39 AM -
Leaking Top Mounts
By chubsta in forum Technical DiscussionReplies: 1Last Post: 06-04-2008, 04:05 PM -
O/B Stock Motor Mounts VS Solid Motor Mounts
By 86vintage in forum Technical DiscussionReplies: 17Last Post: 11-14-2005, 08:42 AM
