Results 1 to 13 of 13
11-15-2017, 07:40 AM #15000 RPM
- Dec 2012
- tn
- 686
- 17
- 46
New to me boat has 2007 150 EFI - motor - good or bad?
Found the hull I wanted (pristine Lowe Tahiti 220 Aluminum deck boat- TOO much room and light weight 22' @ 1400 lbs dry weight) We have a older well loved Tahiti now-
The new Tahiti is equipped with a 2007 150 hp EFI - I have rebuilt a number of EFIs back as carbs because of the simplicity of carb fuel system. I have no experience with EFI system other than taking them off blown motors- normally appears to be lean out on one piston. So not over welling fan of EFIs. I did run one for a summer- it was OK - started quick but other than that not much different than carb.
I have a very nice 2004 XR6 which I could put on the new Tahiti - it has good compression and leak down.
Question is since I am very familiar with carbs and not with EFI - which engine 2007 EFI or 2004 XR6? I do see some value in keeping 2007 hull and 2007 motor together.
One of these motors (EFI or XR6 or maybe '98 175 2.5 noted below) will be for sale after Thanksgiving
The '99 Tahiti with '98 175 2.5 (or one of the above motors) will also be for sale after Thanksgiving-Last edited by CircleHook; 11-15-2017 at 07:46 AM.
11-15-2017, 08:11 PM #2Team Member
- Lake Coochiching, Ontario
- 7,758
- 272
- 485
- 1577
- 6 Post(s)
Both the 150 EFI and the XR6 are 2.5L motors. Are the gearcases the same size? Some XR6 had a smaller gearcase. You would be better off with the bigger case.
11-16-2017, 06:49 AM #35000 RPM
- Nov 2009
- hardyville va
- 367
- 7
- 38
- 43
11-16-2017, 07:26 AM #45000 RPM
- Dec 2012
- tn
- 686
- 17
- 46
I will go with EFI- as much because of keeping the rig all 2007 as anything- Guess I need to get out the book and find out how to winterize it-
So oil pump is not an issue ?
11-17-2017, 01:12 AM #5
keep the efi motor, you wouldn't take the efi off your 2007 chevy 5.3 vortec and make it a carb motor would you ? jmho?
11-17-2017, 07:09 AM #65000 RPM
- Nov 2009
- hardyville va
- 367
- 7
- 38
- 43
11-17-2017, 08:24 AM #75000 RPM
- Dec 2012
- tn
- 686
- 17
- 46
11-17-2017, 09:10 AM #8
11-17-2017, 11:07 AM #9
got beer ? what motor LOL
11-17-2017, 12:42 PM #10
Never really had any issues with those Motors. They get a little chuggy if the injectors get drippy but they run really nice. That last run from 05 to 08 were really strong too
11-17-2017, 02:32 PM #11
yep bump the key its running mamas happy.
11-19-2017, 04:35 PM #125000 RPM
- Dec 2012
- tn
- 686
- 17
- 46
Yes and she does load and unload and that's correct
Yeah let's keep Mama happy
11-23-2017, 05:37 PM #135000 RPM
- Dec 2012
- tn
- 686
- 17
- 46
2007 Twister 24' Class 3C Raceboat ( NO MOTOR )
By Adam McKeon in forum Hulls larger than 20'Replies: 1Last Post: 02-06-2014, 03:41 PM -
300xs mercury 2007 300 hours good price?
By klem in forum General Boating DiscussionReplies: 5Last Post: 08-06-2011, 03:25 PM -
2007 250XS power trim pump motor removal
By cannon20xrd in forum Technical DiscussionReplies: 2Last Post: 12-19-2010, 05:26 PM -
if compression is good is motor good?
By egotsofas in forum Technical DiscussionReplies: 16Last Post: 09-08-2008, 08:02 PM -
2007 75 hp merc tiller motor question
By SammyJo in forum Technical DiscussionReplies: 1Last Post: 05-19-2008, 10:47 AM
