Results 1 to 2 of 2
    Feb 2013
    Sweden
    Question Laser injection, is there any difference between versions?
    Hope to get some help from you guys!
    I have a 2.4 xri from 89, planing on changing the powerhead to a remanufactured 2.5 200 powerhead(part# 813043R97) or a new 225 promax powerhead(part# 809430T01).
    I plan to use as much stuff from the 2.4 as possible.
    I know that I will need to change or modify the exhaust adaptor plates, change the reed plate, stator and regulator (2.4 has the water cooled one) and the ecu for the injection.
    My question is: Can I use the Laser injection stuff from the 2.4 and make it work on the new blocks or is there any difference that makes this impossible?
    Is there anything else that I have missed to take into consideration?
    Feb 2013
    Sweden
    ttt
  1. How can you tell Laser injection from other 2.4 injection
    By jowens in forum Technical Discussion
    Last Post: 10-10-2009, 10:29 AM
  2. Laser Injection
    By tigweld in forum Technical Discussion
    Last Post: 02-12-2007, 08:30 AM
  3. laser injection on a 2.4
    By bondo7 in forum Technical Discussion
    Last Post: 01-30-2004, 08:21 AM
Spinelli Props
