Results 1 to 7 of 7
    Courtice, Ontario, Canada
    3 vs 4 blade props
    I am looking for a prop for my sons Voodoo and have it narrowed down to either a 10.375 x 18" Mercury chopper or a Ron Hill 4 blade semi cleaver through hub that is 11.25" diameter. My question is if going to a 4 blade do you have to pitch down at all? Say to a 16"?
    Thanks
    1996 Allison GSE /200XS
    1989 Hydrostream Voodoo/60 Mercury 3cyl (Kids boat)
    Windsor, Ontario
    I would think 18 in a 4 blade would work.
    Bigger diameter and 4 blades will both hold the rpm down. But 60 on a VooDoo should be mid 50s ore more.
    Mar 2010
    Brigham City, Utah
    I changed from the 3 blade prop that same with the 2011 Merc 150 Optimax to a 4 blade 20P and a huge improvement, this year and half way through the previous season I upped it to 22P and again more improvement.....next year I hope to try out the 23 P MI Wheel Ballistic I have sitting in the shop.
    Karsten
    Mar 2015
    bunnell fl
    I had a Ron hill 4 blade semi cleaver on a little 12' boat with a 60 merc, I believe It was a 17 pitch I could only spin it to like 3500 Rpms I had to go to a 3 blade
    You lost over 2000rpm with just going to a 4 blade? Strange... David, goal is mid 50's which should be pretty easy. An 18" Mercury chopper would be ideal but so far have not had any luck locating a used one for sale. I was thinking of ordering a new 18" Merc chopper but have been told they don't perform as well as the old ones for some reason.
    Windsor, Ontario
    There are some cleavers in your size range on HPBC. You could buy now and sell what doesn't work in the spring. With a light load a cleaver could work.
    I am not sure a cleaver would be the best choice for a lake boat. I have been told by quite a few people that the solid hub is pretty hard on the gearcase when shifting on the small motors. I am pretty sure the seller of those few cleavers on HPBC is in Europe. Also while half of my sons boating is by himself, the other half he has friends in the boat and they are not getting any smaller!
  1. 22P & 24P 3 blade ET Props
    By tjones2937 in forum Propellers
    Last Post: 11-14-2017, 10:04 PM
  2. 5 blade props?
    By 2.5-21 in forum General Boating Discussion
    Last Post: 06-17-2015, 08:00 AM
  3. 3 BLADE vs 2 BLADE PROPS
    By Murry in forum General Boating Discussion
    Last Post: 10-13-2010, 06:25 AM
  4. Best over/thru hub 4 blade props?
    By stoker2001 in forum Props, Setup, and Rigging
    Last Post: 06-05-2006, 05:58 PM
